Technique for a "Rewind" effect at DVinfo.net
Adobe Creative Suite
Old April 18th, 2008, 08:32 AM   #1
What would be the best way to achieve the effect of the video clip, pausing, and then having the classic oldschool slightly scratchy fast rewind, then picking up the action again. I'm thinking that the rewind part is probly easy ( I just cant find the right effect). Adding the horizontal scratchy lines that many associate with this would be a custom AE thing maybe.
I can mock up the sound effect for it.
"...movies are never 'finished', only abandoned..."
-Stephen Spielberg
Ken Bates is offline   Reply With Quote
Old April 18th, 2008, 12:24 PM   #2
Now I'm using Elements, so my process may differ slightly from others.
Right click the clip in the timeline and one of the options is "Time Stretch."
Click on that bad boy and you can change the speed of any clip. Want it 1/2 speed? Type in 50%.
Quarter Speed? Type in 25%
Full-Reverse? Type in -100%
Fast-Reverse? -200, -300
Play around and you'll figure it out...
Will Mahoney is offline   Reply With Quote
Old April 18th, 2008, 12:42 PM   #3
just in premiere, you could design a title of the flashy grey lines and then key frame them to flash on and off, as well as the backwards high speed that is described by Will in the previous reply.
Some random opacity changes to the horizontal lines title would also give you your effect.
Probably not the best way, but it should work.
Good luck
Sony Alpha a57 | RODE VideoMic | Adobe Premiere CS5
Manfrotto 785b | Manfrotto 718b
Russ Holland is offline   Reply With Quote
Old April 19th, 2008, 10:26 AM   #4
Here's what I would do:
Record the portion of video of interest to an analog VCR
Rewind the recording while capturing the output
Hence, you get the real thing and without painful rendering.
John Miller is offline   Reply With Quote
Old April 21st, 2008, 08:52 AM   #5
[QUOTE=John Miller;863475]
[QUOTE]
Simple, low-tech, genuine, brilliant!
Last edited by Will Mahoney; April 21st, 2008 at 08:53 AM. Reason: added "genuine" to my list of adjectives.
