Thread Tools
Search this Thread
Can Blackmagic Decklink HD Extreme output HD & SD simultaneously?
Hi there,
If I'm editing an HD project in Premiere Pro CS3.1, can the Blackmagic Decklink HD Extreme simultaneously output both HD on the HD-SDI output and SD on the component YUV output? Many thanks, Jack |
Here's the answer from Black Magic Design:
"All of the outputs are linked together, so if you activated down conversion on the DeckLink HD Extreme all of the outputs would be SD. This is for both the new and old DeckLink HD Extreme." |
