Weird problem with Dynamic link at DVinfo.net
Adobe Creative Suite
Old April 15th, 2008, 06:06 AM   #1
Hi everyone,
Something weird has happened since I have re-installed my adobe suite (needed doing to solve some glitches..)
In Premiere I have a simple sequence which has three dynamically linked clips from different compositions within the same After Effects file. The first and third clips are still working as before. The second however (which has a 3D camera flyover of a UK map with embedded video clips 'pinned' to the map) has a new problem.
All the video clips (there are about 15) show the default test card image rather than the proper video. However about 2 second from the end of the clip they suddenly appear.... A RAM preview in AE shows everything fine. It also worked fine before I did the re-install.
Any ideas????
Alex
Alex Wren is offline   Reply With Quote
Old April 21st, 2008, 05:36 AM   #2
Anyone?
Sorry to bump my post
Old April 21st, 2008, 09:57 AM   #3
The Test Card is AFX is a file placeholder. Your font of the filenames in the project window is in italic too?
If this is the case, the files have gone/moved. Basically, AFX can't link to them anymore. You'll need to reload the clips to make the test card go away.
Sony Alpha a57 | RODE VideoMic | Adobe Premiere CS5
Manfrotto 785b | Manfrotto 718b
Russ Holland is offline   Reply
