I want to see fields! at DVinfo.net
Adobe Creative Suite
Old April 10th, 2008, 12:27 PM   #1
Is it possible to see the field order in Premiere?
The same way you alt click to see fields in After effects?
I have a weird problem.
I run matrox, so UFF is good.
I've filmed two locations, on two tapes. It seems that the clips/tape from one location have a different field order from the clips/tape from the other.
however, I've checked both tape's clips in AE, and they're both UFF.
But in Premiere when I export to DVD, the field problem is there. I can't see it on the timeline monitor, and even my CRT preview monitor shows no problem. SO that's why I really want to see the fields in Premiere....
Anyone had this problem before? is it a silly thing that's easily fixed?
Chris Coulson is offline   Reply With Quote
Old April 19th, 2008, 01:39 PM   #2
Does it export in Premiere showing the interlace lines?
I've had this before in Premiere, I thought it was a preview thing. Mine exports OK, so I didn't worry about it. Yours might be different though.
Hope that helps.
Sony Alpha a57 | RODE VideoMic | Adobe Premiere CS5
Manfrotto 785b | Manfrotto 718b
Russ Holland is offline   Reply
