Reversing footage at DVinfo.net
Adobe Creative Suite
Old April 9th, 2008, 08:39 PM   #1
Reversing footage
I couldn't think of another term for it, but I'd like to reverse a clip in my timeline, so that it plays from the end to the beginning.
Is this possible in Premiere Pro 2.0 or After Effects?
www.free-range.tv
Tyler Smith is offline   Reply With Quote
Old April 9th, 2008, 08:53 PM   #2
In Premiere Pro 2.0 you can right click on the clip in the timeline, then choose 'Speed/duration' and either put in a negative number (-100 for full speed reverse, -50 for half speed reverse, etc) or click the 'Reverse Speed' box and put in a positive number.
Lloyd Coleman is offline   Reply With Quote
Old April 9th, 2008, 08:54 PM   #3
Yes it's possible atleast in Premiere CS3, you right click the clip you want to reverse in the timeline and select speed and check the "reverse speed", If you don't have that option in CS2 try entering a negative (-100%) value. That should play the video at normal speed in reverse.
... posted nearly at the same time with Lloyd, sorry for the repetition.
Melvin Torrens is offline   Reply With Quote
Old April 9th, 2008, 11:08 PM   #4
Cheers!
That's great, thanks for your prompt reply, both of you.
www.free-range.tv
