PP & AE: Dynamic link in the other direction at DVinfo.net
Adobe Creative Suite
Old March 13th, 2008, 11:01 PM   #1
I wonder how other people deal with synching AE elements so that they appear at the right time on the premiere timeline. For me it's markers all the way.
I do a lot of green screen people talking over background titles. The titles need to synch to what the people are saying. My best workflow so far has been to create black videos in premiere and add loads of markers to indicate when a background title should start/stop. Then copy/paste that black video into AE and start working on the titles. Finally I import the AE comp as a dynamic linked comp into premiere to playback and check that everything is timed correctly.
The downside to this workflow is that when i finally playback the video with the person and titles together, I often see lots of places where the titles need to be on screen longer. So I adjust the edit in Premiere and then have to copy/paste the new markers into AE.
For me, the fastest workflow i can imagine would be if there were a way to import a premiere sequence into AE as a dynamically linked comp. That way, I could adjust the sequence markers in Premiere, when i make changes to the edit, and AE would always show me correct markers so that i could quickly synch everything back up in there too.
Brian Parker is offline   Reply With Quote
Old March 14th, 2008, 07:38 AM   #2
You can just copy part of a sequence from Premiere and paste it right into the After Effects. Instead of markers you can use a few frames of transparent video on a layer above. Then it would be easy to transfer to AE - just copy and paste.
Just a thought.
Bart Walczak is offline   Reply
