HDV to FLV bad quality when exporting using Adobe Media Encoder at DVinfo.net
Adobe Creative Suite
Old January 23rd, 2008, 01:28 AM   #1
I am trying to convert my edited HDV video from Premiere CS3 to FLV using Adobe Media Encoder. So far the quality of the video has been coming out very bad. Worst than a youtube clip. I tried to export a SD clip to FLV and it was much better than the HDV to FLV.
I have been going at this for three days straight and I can't seem to get the FLV files nearly as good as that "HD" look I've seen in other flash vidoes. Now when I export it as a high bitrate at say 6000 then I get DECENT quality but the file ends up being 100MBs. What am I doing wrong? I've have tried Sorenson Squeeze trial and it also yielded decent results with a 1600 bitrate and smaller size.
As for specs. I am using a Sony FX1 captured through Premiere CS3 as a MPEG. I'm guessing it has to do something with the capturing? Also, if I recapture in another format (if possible) will I have to re-edit the video?
Any help is greatly appreciated because I am tired of losing so much sleep over this. Thanks!
P.S. this is my first time working with HDV.
Jimmy Conway is offline   Reply With Quote
Old January 23rd, 2008, 07:04 AM   #2
I too have just started working with HD flv and have not experienced the problems you describe. The only thing that comes to mind is the the Flash encoder may not compress your particular HD video as well as Spark. There are some, with much more experience than I, who believe that the 3rd party encoders are much better than the ones embedded within NLEs. This could be your issue.
That said, I just threw together the first thing I ever shot with my XH A1 and output it to flv and the results were pretty good. Output was 720p, which for Web delivery is about all you need. There were a few new blocky artifacts that showed up in fades to and from black, but nothing serious. The footage was from a local fair and ranged from interior shots with limited action to harness races is bright sunshine.
You might want to try getting a short clip of really clean HD footage and trying again. There might be something about your current footage that is tripping up the codec.
Old January 24th, 2008, 12:10 AM   #3
The weird thing is the high res jpgs that are in the video come out crystal clear. It out shines the actual video footage. Which isn't necessary a good thing.
Old March 25th, 2008, 08:52 PM   #4
figure it out?
Hello,
I have had the same issue. I cut a great 5 min piece captured at HDV and edited in HDV on cs3 and tried to ouput as flash. Usually I do DV and it comes out so much better. It looks so crappy and need to get it up for clients to see. Did you ever figure out the issue? Thanks for any help you can give me.
Ari Perilstein is offline   Reply With Quote
Old March 28th, 2008, 11:51 PM   #5
Flix Pro
Do yourself a favour and buy Flix Pro.. amazing piece of software. The "dumbed down" version is what comes with Premiere. The standalone Pro is outstanding and does two passes etc.
http://www.on2.com/index.php?365
All I can say is I have had outstanding results with both DV and HDV as well as other video formats.
Julian
Julian Maytum
www.MyWebMovie.com
Julian Maytum is offline   Reply With Quote
Old March 29th, 2008, 08:15 AM   #6
Thanks Julian, Flix seems very nice!
Jiri Fiala is offline   Reply
