export to flv (flash) from PPro CS3 at DVinfo.net
Adobe Creative Suite
Old October 13th, 2007, 07:49 AM   #1
Im working with AspectHD in windows XP, dual opterons. 4Gb RAM. Ive just tried to do an export of a DV timeline in PPro CS3 to flv in the Media Encoder, it cant do it, some message about the library appears and the software quits.
Someone has succeed in exporting flash files from the media encoder in CS3?
Thanks in advance!
Hernan Vilchez
kabopro.com myspace.com/kabopro
Hernan Vilchez is offline   Reply With Quote
Old October 13th, 2007, 12:32 PM   #2
I've never had any luck (export fails) from the AME. I have always used AE or the Flash encoder (stand-alone). If either of these are an option for you, do it.
sorry I'm not much help,
Jon
Jon Jaschob is offline   Reply With Quote
Old October 13th, 2007, 06:25 PM   #3
Interesting - I hadn't tried flv encoding since installing CS3 (on a Core2 Duo Windows machine with AspectHD5). Tried exporting to AME just now with a 1080i CFHD clip, and the same clip transcoded to a Huffyuv avi.
Both files crashed Premiere.
Tried the standalone Flash encoder - the huffyuv file encoded fine, the cfhd file produced a 'no valid video stream' error.
So something sure ain't right - will need to experiment futher ....
Old October 15th, 2007, 03:22 AM   #4
Major bug exporting flv from Prem CS3 AME?
We should report Adobe of this, can anyone try to see if exporting flv is possible from Premiere CS3? If not, this would be a major bug!
Hernan Vilchez
Old October 15th, 2007, 11:27 PM   #5
works for me
Since installing CS3 on a fresh PC build, I've exported maybe 20 FLVs from various PPro CS3 timelines without incident. Sometimes, several in one session. The On2 VP6 codec is very fast and efficient. I usually am downconverting from an HDV or SD timeline, and it works great. No crashes or hangs so far.
Here's one render: www.browncowvideo.com/DWBS/promo.htm
I'd suggest you check your Updates and make sure you're using the latest version of PPro and Flash. Also, it's possible that you're experiencing a codec problem, maybe from loading a generic codec package.
my PC specs....
Quad core Intel (Q6600)
8GB RAM DDR2
WD Raptor 10k rpm 150GB system drive
various PATA and SATA HDDs (2TB or so)
Windows Vista 64-bit Home Edition (works great!)
Adobe CS3 Production Premium
HTH,
Brian Brown
BrownCow Productions
http://www.browncowvideo.com
Brian Brown is offline   Reply With Quote
Old October 16th, 2007, 12:01 AM   #6
Brian, are you using Cineform? I'm suspicious that their codec may be a factor in this....
Old October 16th, 2007, 08:49 AM   #7
Graham, I don't use Cineform. Just native HDV files.
If you haven't already, you might try posting the Cineform board here on dvinfo. Their CTO, David Newman, actually responds to most posts and gives good support info.
HTH and good luck,
Brian B.
Old October 16th, 2007, 08:54 AM   #8
Brian, very cool and for a good cause! :-)
Damon Gaskin is offline   Reply With Quote
Old October 19th, 2007, 10:27 PM   #9
OK I solved my problem - which I think is the same as in the original post by Hernan.
CS3's AME was crashing because it was trying to initialize libguide.lib when libguide40.lib was already initialized (perhaps because I have CS2 on my machine as well - dunno about that?).
Anyway, as per the Windows error message I added a new environment variable called KMP_DUPLICATE_LIB_OK and set its value as TRUE ... flash export is now working fine.
To add an environmental variable in XP, go to the Control Panel/System/Advanced tab. Hope that helps.
