No sound in imported clips? at DVinfo.net
Adobe Creative Suite
Old October 4th, 2007, 03:23 AM   #1
I`m editing a wedding video and noticed that there is no audio in some clips so I thought that there really is no audio.
But when I listened those same clips with VLC player there certainly is audio.
Why is that Premiere just cuts audio off in random order?
This really becomes a problem when editing the ceremony part of a wedding.
The clips originated from Canon XH A1 1080i HDV.
Thanks in advance,
T
Toenis Liivamaegi is offline   Reply With Quote
Old October 4th, 2007, 08:28 AM   #2
Do you have a visual confirmation on the timeline that there is audio?
Sometimes we all overlook simple things: have you not clicked by accident on the speaker button and turned off the audio on that track?
Ervin Farkas
www.AtlantaLegalVideo.com
Old October 4th, 2007, 08:34 AM   #3
This happens to me all the time in my CS2 install.
I think it fails in the conforming process.
Usually when this happens, I get audio for the first few seconds of the clip, then nothing for the rest.
Playing the clip in Quicktime outside of Premiere proves that there is audio, but Premiere won't play it all.
Sometimes I delete the conformation files in the media cache folder, thus forcing Premiere to re-conform the clips when I next load the project. This sometimes helps. (But then, you run the risk of another clip that had no audio problems before conforming wrong in this go-around.)
Other times, I just export out a WAVE file from Quicktime and "marry" the original video with this new audio file on the Premiere timeline.
That method ALWAYS works, as I've never had a stand-alone WAVE file fail at conforming. Only video clips with associated audio tend to fail.
Good luck.
James Orlowski is offline   Reply With Quote
Old October 4th, 2007, 10:56 AM   #4
I've had this happen quite a bit. I delete the file from the project, then re-import it. It usually conforms correctly.
Kevin Dorsey is offline   Reply With Quote
Old October 4th, 2007, 05:36 PM   #5
Working during the "conforming" process will do this
In Premiere Pro (1.5 at least) if you begin to edit right after you've imported a file - while the conforming thermometer is moving - you get scrambled drifted, or blank audio. Reconforming fixes this.
Shouldn't PPro only up-sample audio segments which have effects or mixes applied - rather than "conforming" the whole thing at the outset? What do you think guys?
KB
Kevin D Brady is offline   Reply With Quote
Old October 5th, 2007, 12:17 AM   #6
It seems that Pr CS3 on my machine doesn`t like to import and conform more than 5 clips at a time.
T
Old October 5th, 2007, 05:51 AM   #7
Hardware dependent?
Is this error maybe hardware dependent? It never happened to me on any of my PCs, with any version of Premiere. And I had projects where I imported 100 small clips, all at once.
Ervin Farkas
Ervin Farkas is offline   Reply
