Anyone using ToonIt? at DVinfo.net
Adobe Creative Suite
Old September 6th, 2007, 09:11 PM   #1
I am having trouble with memory leakage in a new Premiere plug-in. It's called ToonIt, by Digital Anarchy. It's supposed to "cartoonify" you footage, an excellent idea for certain projects, if it worked! It leaks memory so badly, that it causes Premiere to shut down after rendering about 500 frames. Is anyone out there using this software with success? The Digital Anarchy people say that their copy doesn't leak.
Steve Siegel is offline   Reply With Quote
Old September 7th, 2007, 01:45 AM   #2
Don't know anything about toonit, but this is kinda cool. You need VirtualDub or AviSynth to apply it to your footage.
http://www.compression.ru/video/cart.../index_en.html
Jon
Jon Jaschob is offline   Reply With Quote
Old September 7th, 2007, 04:32 AM   #3
I've used the After Effects plug-in (Digital Anarchy ToonIt), without any problems. Haven't used the Premiere plug-in.
Frank Hardie is offline   Reply With Quote
Old September 21st, 2007, 10:12 PM   #4
I'm co-founder of Toonamation, http://toonamation.com, and we're partnering with Digital Anarchy to release ToonIt!. We write the code that generates the effects. I don't know about a problem specific to Premiere, but on Sept. 9th DA told us about a memory leak reported for Roto1 FAST. Maybe that's what you're talking about. I found the problem and sent DA a fix along with some modifications I was working on that should make everything run considerably faster. DA is currently testing them. Look for a ToonIt! update soon and sorry about the hassle.
Stan Schwartz is offline   Reply
