Time Warp problems in CS3 at DVinfo.net
Adobe Creative Suite
Old August 17th, 2007, 10:52 AM   #1
I'm having a pretty annoying problem when trying to use time warp and I'm hoping there is a solution.
When I turn down the speed of a clip to a very low number, the clip slows down but it does not extend the actual time duration of the clip. This is cutting off a slow-motion scene abruptly and I can not figure out how to extend the duration.
Any ideas?
Fansn.com - Original comedy movie website. Be sure to check out Locker Linebacker, Car Sledding, and the tubing videos!
Chad Huntley is offline   Reply With Quote
Old April 23rd, 2008, 03:23 AM   #2
Yes, me too...i'm trying timewarp in these says and i have the same problem...off course beacuse 'im not good to use it...and i can't find any exhaustive guide..
did you solve ?
Lorenzo Asso is offline   Reply With Quote
Old April 23rd, 2008, 05:34 AM   #3
Time warp is a nice idea that doesn't really work very well. I've not had your problem, but when I use it to slow a clip (50% to 33%) after a cross dissolve, the 15 frames or so runs backwards. As such I've given up using it.
You might try time remapping instead.
Old April 23rd, 2008, 08:39 AM   #4
hello,
i've tried time remapping...very precise and i can do alla what i want and i also found a nice tutorial.
but the treatment of immagine is less accurate that time warp where each frame preseves more quality.
ciao!
