Huge problem edditing with CS3 at DVinfo.net
Adobe Creative Suite
Old August 2nd, 2007, 08:43 PM   #1
I'm probably needing some help from somebody editing in CS3 using CFhd files.
I'm in the middle of a project and my entire sequence lost the recognition of the all the transitions and effects.
Everything was running fine until the Premier Cs3 finished one rendering inside my time line and everything was gone. I'm still able to see my transition in the time line but there is no way to see the them after rendering or exporting the file with the added filters. All my project was started fresh in cs3. This is the first time that I see something like that. I lost all my added properties to scenes even that I'm still able to see them on the timeline. This including opacity, matte key, filters.....
Please is anybody having any idea of what is happening here
I also noticed that when I hit enter inside my time line to do rendering sometimes my program crash. Actually mostly all of the times.
Is that normal for a 2 dualcore 3.0 Hpxw8400 with 4gig of memory?
Is that could be related to the other issue too?
Jose Ortiz is offline   Reply With Quote
Old August 5th, 2007, 05:47 AM   #2
Hi
Have you check out the Adobe forum? It may have answer for you!!
http://www.adobeforums.com/cgi-bin/webx/.3bc44dfb/
K.C. Luke is offline   Reply With Quote
Old August 5th, 2007, 06:55 AM   #3
There is a 3.01 bug fix for PPro CS3 and new builds of all Cineform products that fixed many issues. If you haven't already done those updates, give them a try. If you have, then I'll leave it to someone who is using CS3, which I'm not yet.
Pete Bauer
Old August 6th, 2007, 05:38 PM   #4
Is there a 3.01 update? I don't see it on Adobe download area?
Old August 7th, 2007, 04:48 PM   #5
Thank you guys
Yes I have the updates done of cineform & Cs3 when this happened.
I realized that the error is fixed when you create a new sequence and paste the info there. Additional to reducing the amount of exportation to a minute or so.Before it was just a 4 min line of video with a bunch of filters and transitions.
I'm still thinking that should not be justified I don't recall that issue when I was using Cs2.
