dv wobble problem at DVinfo.net
Adobe Creative Suite
Old August 1st, 2007, 09:37 AM   #1
dv wobble problem
HI great forum everyone ( no the best forum )
so i have been totally frustrated to get this annoying little hop in my footage once it has been exported, i am shooting with an sd dv cam with a 35mm adapter, when i capture the footage (upsidedown) its rock solid no wobble, then i get it on my ppro2 timeline ,vertical and horizontal flip it add a little and export uncompressed, the result has the wobble .
After doing a few searches on this site i found what sounded like a related article only using fcp talking about field order needing to be reversed, so i tried this , i tried deinterlacing , i tried flicker removal ,i tried combinations of the above , i tried them all with and without frame blend? but to know avail. If somebody knows anything about this problem your wisdom would be appreciated.
cheers in advance Rob
Robert Gradisen is offline   Reply With Quote
Old August 1st, 2007, 03:26 PM   #2
ok so dont sweat it havent found the reason exactly , seems the vertical flip is buggy in ppro2 , but have found the solution rotate 180* instead , found the answer in another thread
cheers anyway
