Links to sites for homebuilt dollys, steadicams & cranes at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Additional Camera Support Topics
Old April 20th, 2006, 08:34 AM   #1
Wouldn't it be a good idea to make a sticky thread here with sites for homebuilt dollys, steadicams, cranes...?
Like they have a bit in the Independent Production board.
Mathieu Ghekiere is offline   Reply With Quote
Old April 20th, 2006, 11:43 AM   #2
Good idea. If you'd like to start such a thread then I or one of the other moderators would be happy to "stick" it for you :-)
Old April 20th, 2006, 05:07 PM   #3
Well, in that case, this can be it. I was thinking about only giving sites where they give you information about building it yourself, and not where you only can buy a book where the information is, because otherwise, it's maybe more approperiate for the Reading About it - board.
These are the sites I got via this board, that may help some:
http://www.homebuiltstabilizers.com/
http://www.webbpickersgill.com/stabilizer/
http://steadycamplans.blogspot.com/
http://www.hbsboard.com/
http://homepage.mac.com/visiondigital/PhotoAlbum7.html
http://www.birthofthecool.com/dolly.html
http://www.cs.cmu.edu/~johnny/steadycam/
http://www.shadowgirlproject.com/dolly01.asp (french but with exellent photos, enough to understand without reading)
Hope this helps, and I hope other can contribute to this sticky too,
Old October 17th, 2006, 02:49 PM   #4
translate it
If you want to translate that french site so you can read it as well as look at the great pictures...
Go here: http://babelfish.altavista.com/
in the "translate a web page" box, paste full URL of the page you want translated. Click the button and bam! it's in english (or your preferred language).
I used babelfish on the french site mentioned above, and it worked great!
Lisa Shofner is offline   Reply With Quote
Old September 14th, 2007, 05:25 AM   #5
link graveyard
Wonder if this post should be un-stuck. Only 3 of the links still work (and 2 of those point to different parts of homebuiltstabilizers.com)
just a thought.
-a
Andrew Dean is offline   Reply With Quote
Old September 14th, 2007, 05:30 AM   #6
Agreed -- thanks Andrew,
Old September 23rd, 2007, 06:38 PM   #7
I just purchased a "professionally" built dolly that uses the typical homemade forms... what I got was a 16-wheel on 360-degree swivel, 24.5-inch industry standard width, 28x36 platform, able to hold 600 pounds.... cost $300 plus shipping.
Check out www.glideshot.com. Seems to be pretty good stuff. I'll be using this weekend.
Timothy Donley is offline   Reply With Quote
Old September 26th, 2007, 07:35 AM   #8
I got this thing set up last night on 10-foot PVC and it runs like a charm. Smooth, with me on it (250 lbs.) had no problems... excited about using it this weekend on my shoot. I'll post some vid if all goes well.
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Additional Camera Support Topics
