making a plate with rods for matebox at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Additional Camera Support Topics
Old March 15th, 2008, 07:54 PM   #1
Hi,
I would like to make an aluminium plate with rods to support the camera and a matebox.
I first would like to know if there are standard rods diameter, and standard rods distance ?
I don't know which matebox I will use yet, but it may be a chrosziel. I want to build something compatible, like the Zacuto kit.
any advice ?
[EDIT]
Just found something on the Zacuto website :
The Baseplate comes with 12" support rods that are 15mm in diameter and has a 60mm standard lightweight distance between rod centers.
Can anyone confirm ?
I know there are 2 types of rods, in diameter and distances. Any info ?
Many thanks
Sebastien Thomas is offline   Reply With Quote
Old March 15th, 2008, 08:40 PM   #2
Images: 10
yes, 15mm, 60mm spacing is the convention. hard anodize the aluminum as a finish. Be sure to use threaded inserts for thread holes. Don't attempt to tap the aluminum for removeable fasteners.
Bill Ravens is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Additional Camera Support Topics
