De-interlacing method at DVinfo.net
Old February 27th, 2012, 05:54 PM   #1
I am using pair of consumer camcorders - AVCHD for my 3D @ 60i. When I play the resulting video on TV, it seems o.k. due t the decent de-interlacing technique - I am guessing. When I play back on computer or over internet (YT/Vimeo) I have annoying artifacts due to interlacing. I tried to use several de-interlacers, but I canot find one that works well. Does anyone have any suggestions for good de-interlacer?
Pavel Houda is offline   Reply With Quote
Old February 28th, 2012, 12:47 PM   #2
Re: De-interlacing method
It depends on what platform you're on. Revision FX's Fieldskit is pretty good & also works on many platforms. If you're on Mac, use compressor & set the deinterlacing to "blend". On a budget, try JES Deinterlacer.
Post production is not an afterthought!
www.arniepix.com
Arnie Schlissel is offline   Reply With Quote
Old February 28th, 2012, 03:31 PM   #3
Thanks Arnie. I work on either Windows or MacOS and would like to use decent de-interlacer on either. Your advice is very helpful and I appreciate it.
Old February 29th, 2012, 12:12 AM   #4
Hi
Try ffdshow with deinterlace checked (yadif method)
This gives me smooth result!
Relaxing clips with waterfalls and music, 3D photos, 3D videos:
www.3d-video.hu
Prech Marton is offline   Reply With Quote
Old March 1st, 2012, 03:23 PM   #5
Thank you Prech. I'll give it a try.
Pavel
Old March 1st, 2012, 10:39 PM   #6
I'll second yadif. It beats the adaptive, motion-compensated de-interlacer in Compressor hands down (and every other software de-interlacer I ever tried).
David M. Cole is offline   Reply With Quote
Old March 4th, 2012, 09:23 AM   #7
When is the best moment for de-interlaced? Do you de-interlace L and R clip separeted or do you de-interlaced once the are ensambled?
Thank´s
Pedro Ferrando is offline   Reply With Quote
Old March 4th, 2012, 12:06 PM   #8
De-interlace as a first step, fresh out of the camera. Any transcoding or frame manipulation might have the unintended consequence of blending the two fields from the camera - which need to be pristinely separated for proper de-interlacing.
Old March 7th, 2012, 10:08 AM   #9
How can i play Sony TD10 native files with Stereoscopic Player
with good deinterlace (bob, yadif, etc)?
www.3d-video.hu
Old March 8th, 2012, 09:00 PM   #10
I'll look into the ffdshow, especially since I'm doing all my stereo work on PC.
Does anyone have a sample interlace vs. de-interlaced stereo comparison samples link, so I can see them side-by-side?
Matt Faw is offline   Reply With Quote
Old March 10th, 2012, 10:09 AM   #11
Stereoscopic Player will deinterlace on the fly. Depending on your video card, you'll generally get quite decent hardware deinterlacing.
Old March 10th, 2012, 10:10 AM   #12
FYI - AVISynth can run YADIF as well.
Old March 10th, 2012, 10:29 AM   #13
I have only a geforce 210 card. Can i use this with Stereoplayer for high quality deinterlacing?
www.3d-video.hu
Old March 10th, 2012, 12:13 PM   #14
I've never seen really bad deinterlacing from an NVIDIA card, but, reviews say otherwise for the 210 card:
AnandTech - Quick Look: MSI?s GeForce 210
"The quality is reminiscent of vector adaptive deinterlacing, however it’s not as clean as what we’ve seen on the GT 220."
It's still worth a try.
Old March 10th, 2012, 01:03 PM   #15
When i check deinterlace to on in Stereoscopic player, it will use the gpu hardware deinterlacing? Sure?
After turned on, the horizontal lines disappear, but i don't get smooth motion. I see 25fps progressive (from 50i source), and not 50fps.
I can see my 50i mpeg2 videos at 50fps deinterlaced with bob or yadif method via ffdshow. But when i
load native videos from TD10, i cannot change deinterlace method at "video properties" under used filters.
Only 3dtv.at AVC/MVC decoder is used, and i cannot setup here anything.
So i really need a new video card? A GT240 support good deinterlacing?
thx
www.3d-video.hu
