How will small sensor sizes affect lighting for 3D? at DVinfo.net
Old September 1st, 2010, 07:05 AM   #1
MPS Digital Studios
This is probably an obvious question, but technology is getting more and more advanced, so it might not be an issue... We already know you need a ton of lights for 3D, no matter what type of camera is used. But how will small sensor sizes affect the lighting?
I remember, years ago, comparing a DVX100a to an FX1, and we had to have the Sony's iris open all the way to match the DVX100a at F3.4! We had the set lit to shoot a short film, and it was amazing to see that. Of course, have 1 million pixels on a 1/3-inch chip, you're going to lose something compared to a DV camera's 1/3-inch chip.
However, has technology overcome the pixel-count vs. sensor size issue of light sensitivity?
Heath
My Final Cut Pro X blog
Old September 4th, 2010, 12:34 PM   #2
Why do we need a ton of lights for 3D?
A BS rig will only cost you 1 stop. A pair of modern sensitive cameras such as EX or XF's are not going to need massive lighting rigs.
Old September 4th, 2010, 03:14 PM   #3
MPS Digital Studios
Hey Alister,
I spoke with two experts in the field of 3D, Bernard Mendiburu and Tim Dashwood, and they both explained that you need a ton of light because stereoscope isn't as sensitive to light as 2D cameras. 3D is known for two cameras (or one camera with two lenses and a set of image sensors) and four G&E trucks worth of lights.
3dtv.fr
Dashwood Cinema Solutions
Also, shooting with a lot of dark shadows appears flat in 3D, so you need to add more light to it to bring out the textures.
Heath
Old September 4th, 2010, 11:09 PM   #4
I was also referring to only about 1 stop of loss with a beamsplitter, while emphasizing the need for parallax cues in the background. This means you couldn't shoot a film like "Seven" stereoscopically without bringing up the detail in most of the dark backgrounds, which would of course ruin the mood of those scenes. There's also the polarizers on the projectors to consider during colour correction.
Tim Dashwood
Old September 5th, 2010, 06:28 AM   #5
MPS Digital Studios
Right! I also know that Ridley Scott is going to have to grade the 3D Alien prequels in post. As he said, "The problem is you’ll have to grade it later. You’ll have to grit your teeth and light it not the way you’d like it. And then later, you’re gonna have to regrade it. Repaint it." He said that to Collider.
heath
