The Volunteer 3d Teaser at DVinfo.net
Old June 23rd, 2010, 02:28 PM   #1
Below is a link to both the 3d and 2d versions of the teaser I have made for the movie I'm pitching.
Shot on two 7ds using a homemade side by side rig.
Edited in Final Cut. All stereography and compositing work done in After Effects.
Scripts used in After Effects can be found here.
Many thanks to Mr. Keller for those scripts!
Tim Dashwood's plugin used for previewing within final cut after creating a side by side 3d image in After Effects. Many thanks to Mr. Dashwood for his incredible work.
3d:
YouTube - The Volunteer 3D
2d:
YouTube - The Volunteer 2D
All VFX/stereo work/compositing were done by me. This was my first leap into 3d and there was a definite learning curve!
Ryan Sheffer is offline   Reply With Quote
Old June 23rd, 2010, 04:03 PM   #2
Hi Ryan. Great work! Unfortunately, the 3D version on YouTube looks L/R reversed to me.
Pavel Houda is offline   Reply With Quote
Old June 23rd, 2010, 04:14 PM   #3
What method are you using to view the 3d.? I have a Zalman Trimon 22" monitor I use for the interlaced version and it appears fine.
Old June 23rd, 2010, 04:26 PM   #4
Interesting. Not reversed on my Zalman polarized screen, but reversed on my DLP. Is this a common issue?
Old June 23rd, 2010, 04:32 PM   #5
Realized the issue. Youtube has two interlace settings. One appears to be L/R reversed. That appears to be what I had my video set to preview in.
Old June 23rd, 2010, 04:42 PM   #6
I used "cross-eye" and anaglyph(s). Needed to view "parallel" or reverse the glasses to have the video correct. You already found the issue. Cool work as I said originally. Sorry for bringing the reversal up, I thought you might want to know...
Old June 23rd, 2010, 04:46 PM   #7
Very glad you brought it up. Thanks!
Video should be working now!
Old June 24th, 2010, 11:20 AM   #8
There is no a single scene with correct stereoscopic geometry.
May be you should learn fundamentals of human stereoscopic vision first?
But do not worry, the now famous AVATAR does not have a single undistorted scene either (-:
Mathew Orman
Mathew Orman is offline   Reply With Quote
Old July 2nd, 2010, 02:23 AM   #9
I think Andrew Kramer deserves a very large credit!
Paul Hatcher is offline   Reply With Quote
Old July 2nd, 2010, 10:46 AM   #10
Thanks Ryan. I'm not sure if you realized it (we don't do a great job at marketing this aspect) but Stereo3D Toolbox also works in After Effects CS3, CS4 or CS5 on the Mac, so you don't even need FCP. In fact, you don't even need those AE scripts. I wasn't even aware of those scripts until you linked to the Vimeo video. They are cool (and free of course) but there are a lot of layers and comps to keep track of. If you work in Windows then they are probably the only choice available and Christoph Keller has done a great job at providing a solution for those users.
I will have to do more video tutorials targeted at AE because it really is the compositing and finishing app of choice for most people.
Tim Dashwood
Old July 2nd, 2010, 02:52 PM   #11
I can't fault the compositing and graphics work, but there is way too much disparity in the 3D. You are also doing some pretty fast cutting between scenes with completely different depth brackets which causes the 3D illusion to be lost momentarily around the cut point. There are also the inevitable sync issues associated with non sync cameras. If you watch the anaglyph these become very plain to see as camera shake often moves in opposite directions between left and right eyes.
If your looking to do work for theatrical release or television you should consider the screen size. The amount of positive dissparity in some parts of the clip will be impossible to comfortably view on anything bigger than a 30" screen. Discovery and Sky 3D are working to maximum limits of +5 and -2% and averages of 4% to allow for larger screen sizes and possible theatrical presentation. Remember you can never have more than 60mm of left/right separation on the screen.
Less is more with stereoscopic production. You really don't need or even want massive amounts of dissparity. It's hard to watch comfortably, un-natural and gives all kinds of other issues. The best stereoscopic productions tend to be those that use only small amounts of dissparity as these are the least stressful and tiring to watch, which then gives the viewer the ability to explore the depth in each shot more easily. For the types of scenes in the clip you really need a mirror rig or much smaller interaxial setup, probably IMHO in the 40 to 60 mm range, less for the close ups.
Alister Chapman is offline   Reply
