New 3D HD prototype Sony Blu-Ray camera, shown at Japan World Trade Expo at DVinfo.net
Old June 28th, 2005, 07:17 AM   #1
My friend just returned from expo. The camera is unbelievable. It includes special high speed moving CCD mechanism, allows to record 3D with single lens, picks sound from any area you mark on touchscreen LCD, will measure exposure, white balance on any point you touch on screen, has 1080p24 mode, 50 Mbps MPEG4 - level 10 or something like, to be released in 2008 in same price range as HDV Z1. There was also ultra high definition theater with very large screen, with 24 channel sound, may become available to theaters in about 5 years. That time first beginning ultra high definition broadcast is planned for Japan. Had car there that gets 150 miles per galon, made by Toyota. It was prototype, also personal helicopter with two perpellas, each turning oposite direction, above each other, to be used in low end film, TV productions.
Radek
Radek Svoboda is offline   Reply With Quote
Old June 28th, 2005, 07:27 PM   #2
suspended -- contact admin
So in three years time when HDV becomes mainstream I'm going to have to get this 3-D HDV camera to blow everyone else out of the water ? Lots of robots were at the EXPO so I suppose someday I will have to buy one of those Androids. Hopefully 3-D HDV will come standard along with the ability to wash my dishes.
Tommy James is offline   Reply With Quote
Old June 28th, 2005, 09:48 PM   #3
If its the 3d im thinking, their is no possible way to achieve 360 degree view, from all different angles, standing in one spot with one camera. I dont know, mabye you get to wear those special glasses! sounds retarded, and will never believe such a camera can ever exist.
http://wildlookout.com
Wes Coughlin is offline   Reply With Quote
Old June 28th, 2005, 11:08 PM   #4
Slow down there, Wes...
No-one said anything about 360 degrees.
Traditional 3d capture rigs involve two cameras mounted side by side (Cameron's system) or an optical trick of capturing two adjacent images via a single camera body--from Radek's description, it sounds like the actual optical block is oscillating side-to-side behind the lens, which is impressive!
Nearly all 3D requires the use of glasses. The cheapies are the classic red and blue, or oppositely polarized lenses; the latest have LCD layers that switch on and off, synchronized to the image.
By the way, we discourage the casual use of the term "retarded" around here.
Charles Papert
www.charlespapert.com
Old June 30th, 2005, 01:15 AM   #5
If the CCD block in this camera actually moves physically from side-to-side with each frame, that would be much more complicated and potentially hard on the components, than my proposal: Just electronically shift the sampling zone of the CCDs from side-to-side, timed with the dual frame capture. The shifting of the sampling zone is the basis of electronic image stabilization. Why make it more complicated? Imagine the vibration all that rapid starting and stopping motion would cause if they moved the CCDs mechanically.
J. Stephen McDonald is offline   Reply With Quote
Old June 30th, 2005, 10:49 PM   #6
Finally! Sony uses H.264 (MPEG-4 Part 10) in a prototype HD camera!
Old July 2nd, 2005, 11:18 PM   #7
I understand the ocillating mechanism was inspired by a common apple-peeler. This is good news since I have one and a Pentax Stereo Adapter already, plus a pair of polarized sunglasses, so I should be well on my way to 3D video. One of the greatest difficulties in producing convincing 3D is depth of field control. I think I've found an "eyeball" method using a sharp stick...
Doug Boze is offline   Reply With Quote
Old July 2nd, 2005, 11:34 PM   #8
Can someone provide a link that explains how 3D is achieved with just one lens? Shifting the CCD block/sampling zone, mechanically, electronically, or otherwise, doesn't result anything other than a wider aspect ratio with the exact same perspective projection.
You don't get a sense of depth by closing one eye and swiveling the other eyeball left and right.
All the best,
Robert K S
Search DVinfo.net for quick answers | The best in the business: DVinfo.net sponsors
Robert Knecht Schmidt is offline   Reply With Quote
Old July 3rd, 2005, 01:29 AM   #9
Maybe move one element or group pf elements inside lens, or use something like optical stabilization, where element changes shape. I read someplice that new lens was developed that change shape depending on electrical charge applied and change is practically instanteneous. Who knows what they doing, if they work with Canon or Zeiss on it. Maybe CCD stays stationary and they vary CCD area, where they take sample from, in synch with lens element movement. Who knows. Maybe this little shift in lens and it's moving from one side to another maybe some digital processing calculates, determines how difference would look like if shift was larger.
This is interesting discussion on link below, talks about different way about achieving 3D images on screen without glasses. Maybe this camera needs even different screen that is getting developed. Sony was showing camera privately. Showed it to one known director they know. Maybe mechanism used is similar to mechanism in system where 24 cameras are used as discussed below only there is one camera, everything else is determined by digital processing with new Cell processor.
http://slashdot.org/articles/04/02/25/0846221.shtml
There is push for MPEG4 processing in HDTV. Will allow 1080p50-60 over same bandwidth. This could be used easily for 3D HD pictures. Technology is changes so fast, maybe it will soon possible have 3D HD. Disney already converting 100 theaters to 3D because 3D more profitable. As theaters change to digital, maybe most film productions change to 3D and with all 3D movies, maybe TV will change to 3D.
Radek
Old March 17th, 2007, 04:35 AM   #10
I think they must have considered the various options before choosing this approach.
Seun Osewa is offline   Reply
