MRC1K crashes with windows 7! at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
Including the HVR-MRC1K CF Card Recorder, HVR-DR60 Hard Disk Recorder and others.
Old June 4th, 2010, 04:00 AM   #1
Hi i am tryig to connect the MRC1K unit to my laptop that uses windows 7. I have updated the driver to the "legacy" version. When i connect the recorder the laptop recognises it but when i try to copy the files or even play the files the MRC1k crashes (the display on the MRC1k unit also freezes). At this point i can't even turn off the recorder. I have to take out the battery. Anyone experienced this before?
Colm
Colm Heffernan is offline   Reply With Quote
Old June 4th, 2010, 07:21 PM   #2
I've never even thought to actually connect the unit to any PC. My MRCs are more or less permanently attached to the cams so I just use an external card reader and the Sony-ru Utility to transfer the files to the PC.
Probably not the answer you wanted but worth a try.
Old June 5th, 2010, 12:14 PM   #3
I also just use a card reader, haven't had any problems that way with windows 7.
Canon XH A1; Canon XF100; Nikon D800
Annie Haycock is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
