dc out terminal at DVinfo.net
Old September 20th, 2001, 11:21 PM   #1
dc out terminal
thank you for the reply mark
please explain how the MA-100 or MA 200 use this dc out terminal. Also can I use it to power a lcd monitor or lights perhaps.
Manuel Albarracin is offline   Reply With Quote
Old September 26th, 2001, 05:05 PM   #2
dc output terminal
No to powering lights or LDC panel. Both lights and LCD panels tend to draw a lot of current (on the order of amps) and tend to use higher voltage. At best you may blow an internal fuse and worst case you could blow an internal voltage regulator chip.
The MA100 (and MA200 no doubt) contains small signal amplifiers that convert unbalancd input to balanced output. It draws a very small amount of +5 volt DC current from the dc output terminal.
Don Palomaki is offline   Reply
