Exploring the XL2 Menu System
by Chris Hurd
The Canon XL2 camera menu system goes several pages deep. Here's an outline of the entire menu system, and in the very near future this page will be updated with a little more detail about each menu option. For now you can look over the entire list and get a feel for how extensive it is. Items marked with an asterisk (*) are not available in the 24p modes.
XL2 Menu Settings -- Camera Mode
Time Code
Frame Setting: Drop Frame*, Non-Drop Frame
Count-Up: Rec-Run, Rec Run Preset, Free Run*
Start Value: Set, Reset
Camera Setup
24p Mode Select: 2:3,  2:3:3:2
Zebra: On, Off
Zebra Level: 80, 85, 90, 95, 100
Skin Detail Set: Hue-6 to 0 to +6
Chroma-6 to 0 to +6
Area-6 to 0 to +6
Y-Level-6 to 0 to +6
Skin DetailOff, High, Middle, Low
Zoom Handle: Low, Middle, High
Focus Speed Preset: Low, Middle, High
Clear Scan:
Self Timer: On, Off
Interval Timer: On, Off
Interval: 30 sec., 1 min., 5 min., 10 min.
Int. Rec. Time: 15 frames, 30 frames, 45 frames, 60 frames
Custom Preset
Preset Setup: Select Preset 1 Preset_A,  2 Preset_B,  3 Preset_C
Lock / Clear Cancel, Protect, Clear
Page 1/5:Gamma Normal, Cine
Knee High, Middle, Low
Black Stretch, Middle, Press
Page 2/5:Color Matrix Normal, Cine
Color Gain -6 to 0 to +6
Color Phase -6 to 0 to +6
Page 3/5:Red Gain -6 to 0 to +6
Blue Gain -6 to 0 to +6
Green Gain -6 to 0 to +6
Page 4/5:Vertical Detail Interlace, Progressive
Sharpness -6 to 0 to +6
Coring -6 to 0 to +6
Page 5/5:Setup Level -6 to 0 to +6
Master Pedestal -6 to 0 to +6
Noise Reduction Auto, Off, High, Middle, Low
Read Preset: Select Preset 1 Preset_A,  2 Preset_B,  3 Preset_C
Select Position
VCR Setup
Rec Mode: SP, LP
Power Save: Shut Off, VCR Stop
User Bit Data: Set, Clear
Audio Setup
Audio Mode: 16 bit,  12 bit ch. 1/2,  12bit ch. 1/2 3/4
1kHz Tone: Off, -12dB, -20dB
Audio Monitor Set: Normal, Line Out
Rear XLR Gainup: Off, 12dB
Display Setup
EVF Setup:Brightness -6 to 0 to +6
Contrast-6 to 0 to +6
Color-6 to 0 to +6
Sharpness-6 to 0 to +6
Center Mark:On, Off
TV Screen:On, Off
Audio Levels:On, Off
Guide Info:Off, Custom Keys, D/T Display
Language:English, Japanese
Date Format:
User Bit Display:On, Off
System
Custom Key 1: Time Code, Index Write, Zebra, VCR Stop,
TV Screen, Zoom Handle, Audio Level, (None)
Custom Key 2: Time Code, Index Write, Zebra, VCR Stop,
Wireless Remote: Control 1, Control 2, Off
Tally Lamp: On, Off
Time Zone/DST:
Date / Time Set:
Character Record: On, Off
DV Control: On, Off
XL2 Menu Settings -- VCR Mode
Time Code
VCR Setup
Rec Mode: SP, LP
AV - DV: On, Off
Audio Setup
Select Audio Ch.: Ch. 1/3 2/4,  Ch. 1/3 1/3,  Ch. 2/4 2/4
Mix Select: Variable, Fixed
Audio Mode: 16 bit,  12 bit ch. 1/2,  12 bit ch. 1/2 3/4
Display Setup
EVF Setup: Brightness -6 to 0 to +6
Contrast -6 to 0 to +6
Color-6 to 0 to +6
Center Mark:On, Off
TV Screen:On, Off
Displays:On, Off (Playback)
Six Second Date:On, Off
Data Code:Date / Time,  Camera Data,  Cam. Data & Date / Time
Date / Time Select:Date,  Time,  Date & Time
Custom Keys:On, Off
Date Format:
System
Custom Key 1: Time Code, TV Screen, Data Code, Audio Level, (None)
Custom Key 2: Time Code, TV Screen, Data Code, Audio Level, (None)
Tally Lamp: On, Off
Time Zone/DST:
Date / Time Set:
Back to the XL2 Articles Menu.
Thrown together by Chris Hurd.
©1998-2008 DV Info Net
San Marcos, Texas
We simply must accept the fact that Captain Kirk is no longer alive.
