Sony Announces PXW-X70 XDCAM Professional Compact Camcorder
Sony’s New Compact PXW-X70 XDCAM Professional Camcorder Combines
Benefits of 1” Type Sensor and XAVC Technologies in Handheld Model
Sensor More than 8x the Size of a Conventional 1/3 Single Chip, Powerful Sensitivity & Low-light Performance; Future Updates to 4K Recording & Wi-Fi File Transfer & Streaming
Park Ridge, N.J., July 30, 2014: Sony’s new PXW-X70 professional camcorder is the first XDCAM model to combine the format’s file-based capabilities with a compact form factor. The camcorder records high definition video in XAVC Long GOP, delivering 4:2:2 10-bit sampling at 50 Mb/s to support broadcast-quality workflows in newsgathering and documentary applications.
The PXW-X70 is Sony’s first professional compact camcorder to include Wi-Fi-enabled control via smartphones or tablets using the Content Browser Mobile application. An upcoming upgrade is planned to enable the 4K-ready PXW-X70 to record in 4K Ultra High Definition, and to perform file transfer and live video streaming capabilities.
X70_1
The PXW-X70 features a 1” type Exmor® R CMOS Sensor with a resolution of 20 megapixels. The sensor, which is even larger than the Super 16mm film frame, delivers high resolution and superb low-light performance, while giving shooters more control over depth of field.
This newest addition to the expanding next-generation XDCAM family follows the recently announced PXW-X180, and builds upon Sony’s successful heritage of compact professional camcorders. The new PXW-X70 is designed to be Sony’s most compact XDCAM professional camcorder, and also one of its most versatile, making the flexible XAVC workflow available to a wider range of shooting applications.
PXW-X70 – Key features:
1.0 type Exmor® R CMOS Sensor and Carl Zeiss Vario Sonnar T* lens: High sensitivity and high resolution with 14.2 million effective pixels for striking detail and color, even in low light conditions. The lens offers a 12x optical zoom, which can be increased to 24x with Clear Image Zoom while retaining full resolution using Super Resolution Technology. Zoom performance can be doubled using a digital extender by up to 48x.
Compact, lightweight XDCAM camcorder packed with adaptable professional functions: The PXW-X70 weighs less than 3 pounds, including the XLR handle unit, battery (NP-FV70), lens hood and large eye-cup. Professional interfaces include 3G-SDI and HDMI output connectors, an XLR (2x) handle unit with zoom lever, manual lens ring that can intuitively control zoom and focus, ergonomic palm grip with large zoom lever, two SD memory card slots for backup, simultaneous and relay recording, and a three-level switchable ND filter.
Recording format options: Multiple choices are available depending on application, including XAVC, AVCHD and DV® file-based recording. When recording in XAVC, the PXW-X70 uses the MXF file format, efficiently compressing full HD (1920 x 1080) resolution using the MPEG-4 AVC/H.264 CODEC. Image sampling is 4:2:2 10-bit with high-efficiency Long-GOP compression at 50 Mbps, 35 Mbps or 25 Mbps.
Built-in Wi-Fi control functionality for monitoring and remote control versatility: Near Field Communication functions enable easy, one-touch wireless LAN connection to a smartphone or tablet, while the Content Browser Mobile application allows confirmation of shot angles and operation of the camcorder by remote, including field angle setting, spot focus and iris adjustment.
X70_2
Planned upgrades: Sony is currently working on upgrades to 4K recording, and file transfer and streaming by Wi-Fi. These are planned to be available later in 2014.
The new PXW-X70 XDCAM camcorder is planned to be available this fall, with suggested list pricing to be announced.
Share.
About The Author
