NEWARK, NJ (June 2, 2017) – At Cine Gear Expo 2017 in Hollywood, CA, Panasonic previewed the AU-EVA1, a new 5.7K cinema camera positioned between the Panasonic Lumix GH5 4K mirrorless camera and the VariCam LT 4K cinema camera. Compact and lightweight, the AU-EVA1 is tailor-made for handheld shooting, but also well suited for documentaries, commercials and music videos.
“For cinema-style acquisition, we realized there was a space between the GH5 and the VariCam LT,” said Panasonic Cinema Product Manager Mitch Gross. “With its compact size and new 5.7K sensor, the EVA1 fills that gap for a variety of filmmaking applications.”
The EVA1 contains a newly designed 5.7K Super 35mm-sized sensor for capturing true cinematic images. By starting at a higher native resolution, the 5.7K sensor yields a higher resolving image when down sampled to 4K, UHD, 2K, and even 720p. The increased color information results in a finer, more accurate finished image.
One of the key features of the VariCam 35, VariCam LT, and VariCam Pure is Dual Native ISO. Utilizing a process that allows the sensor to be read in a fundamentally different way, Dual Native ISO extracts more information from the sensor without degrading the image. This results in a camera that can switch from a standard sensitivity to a high sensitivity without an increase in noise, or other artifacts. On the VariCams, Dual Native ISO has allowed cinematographers to use less light on set, saving time and money, as well as allowing for a great variety of artistic choices. The EVA1 will include Dual Native ISO, but the camera is currently being tested to determine final ISO specifications.
The ability to capture accurate colors and rich skin tones is a must for any filmmaker. Like the VariCam lineup of cinema cameras, the EVA1 contains V-Log/V-Gamut capture to deliver high dynamic range and broad colors. V-Log has log curve characteristics that are somewhat reminiscent of negative film and V-Gamut delivers a color space even larger than film. The EVA1 will also import the celebrated colorimetry of the VariCam line.
Weighing only 2.65-lbs (1.2Kg, body-only) with a compact form factor (6.69” x 5.31” x 5.23”) and a removable handgrip, the EVA1 can be used for efficient handheld shooting applications and can also be mounted on a drone, gimbal rig or jib arm for complex yet smooth camera moves. There will also be numerous mounting points and Panasonic is currently working with top accessory makers to allow further customization with the EVA1.Ideal for indie filmmakers, the EVA1 records to readily-available, lower-cost SD cards. The camera can record in several formats and compression rates, and offers up to 10-bit 4:2:2, even in 4K. For high-speed capture, the EVA1 offers 2K up to 240-fps. In terms of bitrates, you can record up to 400-Mbps for robust recording. A complete breakdown of recording formats will be available at the time of the EVA1’s release.
As a professional video production tool, the EVA1 offers dual balanced XLR audio inputs and 4K-capable video outputs in both HDMI and SDI. In a future firmware upgrade, EVA1 will offer 5.7K RAW output to 3rd party recorders.
The EVA1 will ship this Fall for under $8,000 (body only).
For more information about the AU-EVA1, visit http://business.panasonic.com/products-professionalvideo.
About Panasonic Broadcast, Cinema and Professional Video Systems
Panasonic offers leading products to acquire, transmit and view high-quality video, over both video and IP networks. Professional products include VariCam cinema cameras, P2 HD camcorders, 4K and HD handheld cameras, Pan/Tilt/Zoom cameras, studio and box cameras, switchers and monitors. These products serve customers in cinema, broadcast, professional sports, higher education, enterprise and other markets.
About Panasonic Corporation of North America
Newark, NJ-based Panasonic Corporation of North America is a leading technology partner and integrator to businesses, government agencies and consumers across the region. The company is the principal North American subsidiary of Osaka, Japan-based Panasonic Corporation and the hub of Panasonic’s U.S. branding, marketing, sales, service and R&D operations. Panasonic was featured in Fortune Magazine’s 2016 ranking of 50 companies that are changing the world and doing well by doing good. Specifically cited were its smart and sustainable technologies, including its contributions to smart cities and the electric vehicle revolution.
