Blackmagic Design Announces New URSA Mini Pro 4.6K Camera
New camera combines incredible digital film image quality with broadcast camera features, built in ND filters, interchangeable lens mount and more.
Fremont, California, USA – March 2, 2017 – Blackmagic Design today announced URSA Mini Pro 4.6K, a new professional camera that combines high end digital film quality with the ergonomics and features of a traditional broadcast camera. URSA Mini Pro features a massive number of tactile control buttons, switches and dials that make it faster to use, built in optical ND filters, a new interchangeable lens mount, dual CFAST 2.0 and dual SD/UHS-II card recorders, and much more.
URSA Mini Pro 4.6K is available now for $5,995 from Blackmagic Design resellers worldwide.
The new URSA Mini Pro combines the best digital film technology with the most advanced broadcast features and ergonomics available, making it perfect for use in high end feature films, television shows, commercials, and indie films as well as broadcast news, studio and even live multi camera production.
URSA Mini Pro
URSA Mini Pro is designed to be the toughest and most fully featured camera available. It includes everything customers need in a compact handheld magnesium alloy body that’s durable and light enough to use anywhere. There’s an external high visibility LCD status display for viewing critical shooting information, a foldout touch screen for reviewing shots without needing an extra on-set monitor, professional connections such as 12G-SDI, XLR audio, built in high quality stereo microphones and more. Plus, every single control on the camera is redundant, including the power, so if anything should go wrong in the field, the camera can still be used.
When it comes to image quality, URSA Mini Pro features a custom 4.6K image sensor that captures up to 4608 x 2592 pixels with a massive 15 stops of dynamic range and a super wide color gamut. Third generation Blackmagic Design color science is used to process the raw sensor data, enabling amazingly rich skin tones, natural color response and an enormous amount of dynamic range. URSA Mini Pro is ideal for everything from standard rec. 709 broadcast HD to the latest rec. 2020 high dynamic range digital film production.
URSA Mini Pro features neutral density (ND) filters with IR compensation for quickly reducing the amount of light that enters the camera. The 2, 4 and 6 stop filters are specifically designed to match the colorimetry of the camera and provide additional latitude, even under harsh lighting conditions. That means customers can use different combinations of aperture and shutter angle to achieve shallower depth of field, or specific levels of motion blur, in a wider range of situations. The IR filters evenly compensate for both far red and infrared wave lengths to eliminate IR contamination. The ND filters are true optical filters with a precision mechanism that quickly moves them into place when the ND filter dial is turned.
The broadcast camera ergonomics of URSA Mini Pro put powerful tactile control buttons, switches, knobs and dials on the outside of the camera, giving customers direct access to the most important camera settings. The controls are laid out in a logical order that makes them easy to remember so cinematographers can operate the camera without having to look at the buttons, hunt through menus, or take their eye off of the action. URSA Mini Pro also features a high visibility status screen that displays important information such as timecode, shutter and lens settings, battery, recording status, and audio levels. The status display features a backlight and is designed to be clearly visible in both dimly lit studios and outside in direct sunlight.
URSA Mini Pro Rear Angle
URSA Mini Pro has a revolutionary new interchangeable lens mount that makes it compatible with virtually all professional lenses so customers can choose exactly the right lens for the job. Included standard is an EF mount for working with high quality photographic lenses. If the camera is being used on a high end film or commercial shoot that calls for large cinematic lenses, simply remove the EF mount and replace it with the PL mount. There’s even a B4 broadcast lens mount for working with broadcast HD lenses. URSA Mini Pro also includes a standard 12 pin Hirose lens control connector. URSA Mini Pro comes with an EF mount and customers can purchase the optional PL and B4 lens mounts separately.
Featuring both dual C-Fast 2.0 recorders and dual SD/UHS-II card recorders, customers can choose the media that works best for their projects. C-Fast cards are ideal for full resolution RAW recording, while UHS-II SD cards are inexpensive and commonly available, making them perfect for recording ProRes Ultra HD files or RAW HD files. Simply choose the media type, insert the cards and start shooting. With dual slots for each media type, the camera never has to stop recording because when the first card is full, it automatically continues onto the next card. Full cards can be swapped for empty ones, all without stopping the camera. URSA Mini Pro can record lossless 12-bit CinemaDNG RAW files for the highest possible quality, or 10-bit ProRes files for easy post production workflows with minimum storage requirements.
URSA Mini Pro includes the full DaVinci Resolve Studio software, giving customers a complete post production solution. This powerful software combines professional nonlinear video editing with the world’s most advanced color corrector for importing, editing, color correcting, finishing and delivering projects shot on URSA Mini Pro. DaVinci Resolve Studio works natively with the RAW and ProRes files from the camera, so customers can take them directly into post production without having to convert or change them. Every single bit of quality is preserved because it is a true lossless workflow. Using DaVinci Resolve Studio is the fastest and highest quality way to work with files from URSA Mini Pro.
“Professional DoP’s and cinematographers love the incredible image quality of URSA Mini and we have been working with them and listening to their feedback,” said Grant Petty, CEO, Blackmagic Design. “URSA Mini Pro is so exciting because it combines high end digital film quality with broadcast camera and live production features, all into a single camera. URSA Mini Pro is powerful enough to be used on high end feature films and television shows, versatile enough to be used for broadcast news and live multi camera event production, and affordable enough for indie filmmakers and even students! It’s like getting 3 cameras in one!”
Blackmagic URSA Mini Pro Key Features
  • Digital film camera with15 stops of dynamic range.
  • Super 35mm 4.6K sensor with third generation Blackmagic Design color science processing of raw sensor data.
  • Interchangeable lens mount with EF mount included as standard. Optional PL and B4 lens mount available separately.
  • High quality 2, 4 and 6 stop neutral density (ND) filters with IR compensation designed to specifically match the colorimetry and color science of URSA Mini Pro.
  • Fully redundant controls including ergonomically designed tactile controls which allow direct access to the most important camera settings such as external power switch, ND filter wheel, ISO, shutter, white balance, record button, audio gain controls, lens and transport control, high frame rate button and more.
  • Built in dual C-Fast 2.0 recorders and dual SD/UHS-II card recorders allow unlimited duration recording in high quality.
  • Lightweight and durable magnesium alloy body.
  • LCD status display for quickly checking timecode, shutter and lens settings, battery, recording status, and audio levels.
  • Support for CinemaDNG 4.6K RAW files and ProRes 4444 XQ, ProRes 4444, ProRes 422 HQ, ProRes 422, ProRes 422 LT, ProRes 422 Proxy recording at Ultra HD and HD resolutions.
  • Supports up to 60 fps 4.6K resolution capture in RAW.
  • Features all standard connections, including dual XLR mic/line audio inputs with phantom power, 12G-SDI output for monitoring with camera status graphic overlay and separate XLR 4 pin power output for viewfinder power, headphone jack, LANC remote control and standard 4 pin 12V DC power connection.
  • Built in high quality stereo microphones for recording sound.
  • 4-inch foldout touchscreen for on-set monitoring and menu settings.
  • Includes full copy of DaVinci Resolve software color grading and editing software.
URSA Mini Pro Side Angle EF Mount
Availability and Price
URSA Mini Pro is available now from Blackmagic Design resellers worldwide for US$5,995. Also available from resellers are the optional URSA Mini Pro PL lens mount for US$245, as well as the optional URSA Mini Pro B4 HD lens mount for US$385. URSA Mini Pro comes standard with an EF lens mount, and additional replacement mounts can also be purchased for US$175.
Blackmagic URSA Mini Accessories
Blackmagic URSA Mini Pro PL and B4 lens mounts each sold separately.
Additional Blackmagic URSA Mini Pro EF lens mounts also sold separately.
Blackmagic URSA Mini Shoulder Kit features built in rosettes, rail mounts, viewfinder mount, integrated tripod quick lock release and top handle.
Blackmagic URSA Viewfinder is a high resolution viewfinder that includes a full HD OLED display and true glass optics for perfect focus.
Blackmagic URSA Studio Viewfinder featuring 7” screen, variable tension mounting points, grab handles, external controls and more.
URSA VLock Battery Plate provides a VLock compatible plate for attaching third party batteries.
About Blackmagic Design
Blackmagic Design creates the world’s highest quality video editing products, digital film cameras, color correctors, video converters, video monitoring, routers, live production switchers, disk recorders, waveform monitors and real time film scanners for the feature film, post production and television broadcast industries. Blackmagic Design’s DeckLink capture cards launched a revolution in quality and affordability in post production, while the company’s Emmy™ award winning DaVinci color correction products have dominated the television and film industry since 1984. Blackmagic Design continues ground breaking innovations including 6G-SDI and 12G-SDI products and stereoscopic 3D and Ultra HD workflows. Founded by world leading post production editors and engineers, Blackmagic Design has offices in the USA, UK, Japan, Singapore and Australia. For more information, please go to www.blackmagicdesign.com.
Share.
About The Author
