move clip to timestamp
Hi ,
is there a way (or a script) to move clips to their origin timestamp? You can easily find the timestamp under "clip properties" or display (media fx) the recorded timecode - but how can I move selected (or all) clips to their timecode position? Thanks ULI |
Yes, but perhaps not as easily as you like. There is a highly automated function for automatically distributing broadcast wave files on the timeline at their time stamp, but, doing so with video is a highly manual function.
First, I suggest turning on timecode display on events. Options | Preferences | Video | Show Source Frame Numbers on event thumbnails as | Timecode. Let's say your first clip has a starting timecode stamp of 00:14:37;24. With focus on the tracks (Alt-0), hit Ctrl-G. This will bring focus to the timecode display at the lower right of the timeline, and it will be highlighted and editable. (you can also click on it, but things go much faster with keyboard shortcuts). Type in 14.37.24 and hit the return key. Now, the timeline cursor should be at that desired position. Now, drag the clip to the timeline and snap it to the cursor position. If you're doing a series of clips, it makes sense to go to prefs | General and unclick Double click on media files loads into trimmer instead of tracks. Now, you can just double click on a file in explorer or project media and it will load to the timeline at the cursor position. Possible bug - I've had the experience in a new project with Vegas 7 where the cursor won't go to the desired position. The workaround I've used is to drag a clip out past my work area, later in the timeline, and then everything seems to work as it should. I find this workflow to be very manageable for long clips that I typically shoot in concert/event situations, it probably gets tedious if you have lots of small clips but it will work! PS. I'd also like to know if this is scriptable... if scripts can look at starting timecode it should be possible. |
Thanks for the reply - yes, this method works (I found that start position of the clip can be edited under "edit details" as well).
Unfortunately , with some events (company anniversaries) I have ~100 or more clips (timecode-splitted) , so this method is too much work... I hoped there is an automatic function for that. IŽll have a try to find someone who programs scripts - perhaps I can make a deal with him. // BTW: Why I am so heavily interested in that is that I like to render avi files from the timeline, that have THE SAME TIMECODE information like the original clips - with Vegas it works only by rendering from the correct Timeline position... THanks ULI |
It may be possible to do that via a script. I'll have to look into the API to be totally certain.
See if this script does what you're wanting. I tested it under Vegas 7 but it ought to work under Vegas 6 (at least 6.0c or newer).
Umm... what's a year between forum members?
Edward, I found this old thread on an unrelated search and just tried out the script - it works great! Thanks!!! For anyone interested, it will sort all clips on the timeline to a timeline position corresponding to their starting timecode. If you go into clip properties and modify the "use timecode" parameter, that clip will be sorted to the new tc when the script is run. Really appreciate it Edward - Seth ***EDIT*** PS. Tested on V7 and V8 PPS. Keep an eye on multiple clips on multiple tracks - Frequently, one clip will not move to correct TC. PPPS. Anyone interested in these functions on V8 should also check out Tools | Multicamera | Lay Out Tracks Using Media Timecode |
Paul. |
| All times are GMT -6. The time now is 02:46 PM. |
