-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Time Lapse I did in Vegas (https://www.dvinfo.net/forum/what-happens-vegas/90232-time-lapse-i-did-vegas.html)
Steven Bills March 29th, 2007 12:49 PM
Here's a time lapse of some wispy clouds on Mt Rainier (in Washington State). I rendered every 6th frame as an image sequence, and then brought it into After Effects to CC and then rendered it out.
http://www.yousendit.com/transfer.ph...2FEDBD7328E25F
I have the HD (720p) version if anyone wants it.
SB
Edit: HD version: http://www.yousendit.com/transfer.ph...06BC03336A91AE
Seth Bloombaum March 29th, 2007 01:39 PM
Hi Steven, nice timelapse! (nice mountain!)
Was this one tape's worth of shooting, or did you change tapes or record on a hard drive?
Steven Bills March 29th, 2007 04:44 PM
That was only 20 minutes of tape, actually.
Matthew Amirkhani April 1st, 2007 08:22 AM
Hi Steven,
Thanks for sharing your clip with us, I have a question for you I have a 15 minute cloud footage that I need to do the time lapse, but I have no clue as how to do it in Vegas is it possible for you to explain it in details for me please?
Thanks in advance
Matthew
Chris Barcellos April 1st, 2007 11:10 AM
One way: Put the clip you want to shorten on a timeline in Vegas. Put your cursor at either end of clip so that it looks like you are selecting to shorten the clip. Left click and depress contol key at same time. A squigley line will come up, and then you can shorten or lengthen to particular clip. That goes 4x it looks like. Maybe rerender a couple of times shorten clip each time.
James Hooey April 1st, 2007 08:35 PM
Hi Steve,
How did you grab evey sixth frame in vegas? Was this done by hand selecting individual frames?
When I have done timelapses in Vegas I use the velocity envelope to speed up clips as much as 300% and render these clips back to m2t files until I need them in a project. (repeat this process for even more sped up effect)
I would be very interested to know if I could actually run some sort of vegas script that would grab discreet frames and drop them to an seperate timeline. This may save a great deal of rendering and possibly achieve better results.
Anyone care to comment?
Douglas Spotted Eagle April 1st, 2007 09:24 PM
James,
Ultimate S can grab every 'n' frame if that's what you want to do. There are other scripts, I believe, that can set up a frame sequence export as well.
Edward Troxel April 1st, 2007 09:40 PM
Yes there are. Excalibur can also do it. However, you might look at the free scripts like this one and modify it to meet your needs.
James Hooey April 3rd, 2007 06:14 PM
Hmmm....I should have looked at Vegas a little more closely before posting my question. Turns out it has a very handy little script already included with version 7 for just this sort of idea. It lets you choose the interval at which to grab snapshots from a video clip and exports them as sequential jpg filenames. All I needed to do after that was bring them back as stills setting a very short still picture duration from the editing preferences. After rendering this out as a new movie ....voila....another method of timelapse other than velocity enveloping clips. It has a slightly different look as well with a crisper image instead of blurring. Not necessarily better...but different.
Thanks for the previous info too...I tried the script you made Edward and I like the fact it makes png files.
Steven Bills April 3rd, 2007 07:00 PM
Here's how to do it...
Wow, thanks for all the kind words guys. I've been gone the past few days, so I haven't been able to reply. Anyways, to render out every nth frame, say, for a time lapse, go to Tools > Scripting > Render Image Sequence. The Image Sequence dialog box will pop up, and there you can choose the destination for all the images, file name, file type, start and end times, and at the very bottom there is a field for 'Step Time'. It's default setting is set at 00:00:00:01. With that setting, it will render every frame, so for this particular time lapse, I changed the values to 00:00:06:00. That is 1 frame per every 6 seconds. So once the render got done, I imported the image sequence into After Effects, and then CC'd it, and rendered it out.
Bam. Done.
SB
Joey Atilano April 5th, 2007 11:37 AM
Footage from Sony HDR-HC3 ?
Hey Steven I thought you had said at one time you had a Sony HDR-HC3 . Nice video.
Steven Bills April 6th, 2007 04:02 PM
Yep, the footage is from the HC3.
