Capturing from my TV using the XL1s and Vegas
I know I can use my XL1s to preview a project I am working on in Vegas (5.0) on a TV via firewire and the a/v outs, BUT how do I capture a DVD playing from my TV into Vegas?
Thanks! p.s. I tried going to FILE then CAPTURE VIDEO but all it does is look at the tape inside the camera. |
DVD -> tape -> Vegas
You could go to tape as an intermediate or you could turn off device control and just use the camera as a convertor.
When I look through my eye piece on the xl1 it says "a/v in" so I guess I have it hooked up correctly. I just need to know the steps to capture what my TV is playing using my xl1 as a convertor and Vegas. |
64 people looked at this post and know one knows?!?! =)
Oh well thanks for trying, if I figure it out I will post how I did it. |
Patience, Oliver.....:-)
Connect your television to the analog inputs of the XL Connect your XL to the Firewire card on your computer Put your XL in VTR mode. Enable the capture utility on the computer/Vegas. Done. Many, many people use their camcorder as pass-thru/converter devices, it's very easy, I'm thinking that maybe folks are under the impression you wanted to do something more complicated. That's what I was thinking. |
One more thing to make sure that I mentioned in the previous post: turn OFF device control in the capture program. Otherwise it will try to capture from a tape instead of the pass-thru.
Oliver, I have XM2s. The lowlier XL Canon. When I first started out, I HAVE done exactly this. Use the Camera as a Pass Thru' device.
If I had seen this thread, I wouldn't wanted to reply as I don't have the more PRO XL series - yeah? Meaning, maybe the PRo-er version wouldn't allow for pass thru'? I could quite easily confused the thread here. Now we HAVE got this far, I can also say that when I did do this, I needed to set the XM2 to ALLOW for Pass Thru. There are some caveats to this process. Least of which is the copy protect signal that can stop the signal in its tracks. Neither can I have a tape in the camera. |
I am using Vegas 5.0. Thanks a lot for the info Douglas & Edward, I feel like I am getting closer. =) p.s. Graham, I have no idea what your talking about.... |
whoops (I'm dumb), the box to uncheck has to be done in the window that comes up when you click capture video. So you: click capture video / options / preferences / its the 1st box.
But I still don't get a picture, it stopped looking for a tape after I turned the DV Device Control off and the screen went from blue to black but I'm not getting a preview / input to capture anything. Maybe Graham knows something we don't about the "copy protect signal"? BUT like I said on my 1st post I CAN use the XL1s to preview on an external monitor when I am working on a project in Vegas so shouldn't it work the other way? Thanks Guys. |
Why would you not put the DVD into your computer and rip the contents to an .avi file? that'd avoid unnecessary digital->analog (composite or svideo)->digital conversion.
Just a thought. Kyle |
You could use the various ripping tools available but I prefer doing it the easy way myself :-) |
That's what I want to do also, but what format
