Add Clip Name to Render
I am creating an edit copy for my clients thast includes the clip time code, total time code, and clip name so they can look at the raw and pick shots, etc. THe only thing left to figure out is clip name. I can get the clip name to appear in the time line but I want it rendered on the video just like a time code.
Is there any way to do this? I have a huge library of scripts (most of which seem to be broken) and none do this. It isn't too critical since I can just keep the project file and refer to the total time code (which exists as an fx on a text overlay track) in order to find out what the customer is referring to. But I might be nice to have the clip name as well. Any suggestions? I haven't created a script before so I can't write my own (yet). Being a sw developer full time, I suppose I should get into the vegas scripting habbit to save myself time in the long run. Thanks again. Jason |
can you take a generated media text, type in the clip name and other info reposition it to where you want it and render it that way?
Don |
A script cannot change the text in a generated media. It can create the generated media - just can't change what it says.
The best I've been able to do is the Quick label tool in Excalibur. |
That would be the manual way
jason |
Ahhh
jason |
It will first create regions around each image, name the regions for the file names, create images from those region names, and then overlay those images over the original pictures.
round about?
jason |
The regions aren't technically necessary and the large round-about method is because of limitations in Vegas. Right now, the tool works with regions (allowing you to put any name YOU want in any particular area) but can automatically create the necessary regions and name them the file name.
Thread resurrection
What I wondered was I cannot see any screen caps of waht the text labels will look like when rendered. Will they look like a generated media clip? I know that a script cannot change the text of a generated media clip, but can a script create the initial generated media file? as in.... 1) select all media that I want labeled 2) tell script "create a label for each media on this track" 3) script creates new generated media files for every media on the timeline on that track and places these generated media files in a new track (or existing track) above the media. 4) I render the project and see the media name in text appearing next time my time codes (one for clip and one for total). Or does the script takes the clip names and creates pngs or jpg from the clip name and then put the image above the media? In either case, I'd love to see a screen shot of the preview window so I can see what it is the page is describing. Excalibur Quicklabel |
Go to this page instead:
Excalibur 5.5 Quicklabel This is how it looked in the previous versions of Vegas/Excalibur. At the top of that page you'll see multiple videos including one that deals with Quick Label. The results are the same in Excalibur 6 - I just didn't redo the video to show the new GUI. |
No. The visible labels are PICTURES/images. Just like going to a paint program and typing text there, saving it, and then adding the picture to the project - just totally automated. Scripts do not have access to the individual generated media settings (can only set presets).
