Keying with vegas
Hello
Does anyone know any other keyer other then the standard one in vegas? cant seem to find any info on it but can primatte 3 work with vegas or only after effects? i am after a add on or plug-in that is going to give me a better key with green then the standard one Thanks for your time |
What problems are you having? Vegas keys brilliantly with green.
It'll key any color (or range) you specify.
Working with DV, blue is sometimes problematic, because the blue channel can be noisier than the others. |
I'm still looking for a project to justify purchase, but *many* people have reported great results with Serious Magic Ultra 2 for green-screen with DV. seriousmagic.com.
There's a forum here covering Ultra and DVRack (also an SM product). |
I'm a major fan of Ultra 2 for speed, but I can achieve nearly as good a key with Vegas in *most* cases, but it takes more time.
With Ultra, or Vegas, you can key from any color, but red specifically is the most difficult key in DV, due to the way DV samples. You can easily use lighter blues, but as David mentions, blues, or specifically deeper hues, can cause a problem. This is due to how DV samples. Luma value is the key factor in any color. |
Hello
Its HD i am keying with just posted in wrong topic Any how when i try to key the green out its taking some of the subject out with it the screen isn’t lit as best as it could be but i don’t have a lot to work with it does ok but then when i want to insert another back ground over it you can still see some of the green. is there any way of brightening up the background without touching the subject so it makes it easier to key? Thanks again |
You've got sliders in the key editor. Try bringing the low up and the high down.
Also, you can use the secondary color corrector to saturate the green and only the green -- apply that before you apply the chroma keyer. |
Cleaning up the edges
I am having pretty good results keying out an object with fine lines against a blue background. Both are computer generated. I am using Chroma Blur, Secondary Color to saturate the blue since it is a "sky" and some unevenness is there, and then finally the Chroma Key.
But now I have a fine blue finge/noise around the object. I went to this forum http://www.dvinfo.net/conf/showthrea...roma+secondary The suggestion there is to put the Secondary Plug in AFTER the Key plugin. Can someone explain the difference in what is being done here? I thought you would need the secondary CC before the key so you could get a great key. Thoughts? Things look good except that pesky blue noise..... |
No, you need to correct the keyed color before you try the key, so put the corrector in before.
Also, adding a chroma blur between them may help some. What's being suggested in that thread is to use a secondary corrector for post-key cleanup. You apply it only to the keyed image to try to mitigate the spill. You wouldn't be making the blue more blue; you'd try to get rid of it entirely. |
the order in which you want to do this is: 1. Secondary color corrector to even out the blue 2. Chromablur set to a value of 2.0 (assuming DV source) 3. Chromakey tool 4. Any color correction for the subject in the key itself. |
No. Step 4 is for correcting the SUBJECT within the image. If it comes post-key, it won't affect the blue at all.
Did you shoot blue with a DV source? If so, you're likely going to need to create a garbage matte. Blue isn't a good option for DV sourced-material. You really needed to use green, for the substantially higher luma value. To create a garbage matte, I have a tutorial at: http://www.vasst.com/resource.aspx?i...f-b305852df8a7 |
Great tutorial - an easy way of creating a travelling matte. I will give this a try.
I do have another question regarding masking out areas to be keyed. I have this object and I use the Bezier tool to mask around it leaving a little of the blue area to be keyed out. When the object is against a lighter background I can make out the edges of the area I've masked out! This does not seem to happen with cookie-cutter but the bezier tool is great for creating a custom shape. What is better to use - the bezier tool or cookie cutter? And when using the bezier tool is it generally better to feather - in - out - or both to clean out the mask line? |
HTH |
