-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Networking for Vegas 6 (https://www.dvinfo.net/forum/what-happens-vegas/53854-networking-vegas-6-a.html)
DJ Kinney November 5th, 2005 12:40 AM
Okay. So the computer geek is finally tired. I just can't play these games any more. I have to ask a question, because problem solving doesn't thrill me as much as it used to.
I finally have another computer and I want to do network renders. One is a laptop, the other, my normal desktop. Both are XP (one Pro, one home) and both are fully outfitted.
What is the best/fastest way to network them. Ethernet cable (if so, how) wireless (if so, must be ad hoc, as I have to router) or perhaps a usb 2.0 connection.
What do you all think? Oh, and a brief explanation of the rudimentary elements of making the network render work.
This should be a heavenly question for a computer nerd who still has the energy to deal with the little silicon beasts.
Newdjeen Klime November 5th, 2005 01:49 AM
For two computers only you do not need router, switch, hub or another network device - You can connect computers with a "crossover" cable. After plug cable in to two computers you need adjust them Ethernet controllers on TCP/IP protocol
Why Ethernet it is better, because this most stable connection.
For network rendering you need network licens (One serial number for Vegas with a various activation codes)
PS Sorry 4 my English
DJ Kinney November 5th, 2005 01:08 PM
That's O.K. I got the gist of it. Thanks! Basically you're saying an ethernet crossover cable between the two computers and creating a network link will automatically connect them for Vegas.
Does anyone do this? Is it a wonderful boost in speed?
Edward Troxel November 5th, 2005 01:17 PM
First of all, not all formats can be network rendered. And for those that can, the benefits are project dependent. If the project has lots of effects, network rendering can help. If you only have a few dissolves here and there, you probably won't see much benefit. So it's really hard to say how much benefit YOU would get from it until you try it with your projects.
DJ Kinney November 5th, 2005 02:29 PM
O.K. Thanks. So it doesn't just chop up the workload and distribute the pieces? Say, for rendering a bunch of clips and cuts to a DVDA mpeg.
Because in an ideal world, I was thinking (simplistically) that half the project would be done with one system, the other half on another, assemble and spit out. I guess that's not the case.
Edward Troxel November 5th, 2005 03:00 PM
MPEG2 is one of the formats where a single file CANNOT be rendered in pieces on multiple machines. The problem is the stitching point at the end - MPEG2 can't be stitched. However, you COULD use network rendering to set the various machines to individually render separate complete files.
Yi Fong Yu November 7th, 2005 02:51 PM
whoa, i didn't know that. i thought MPEG2 could. =). thx Ed.
another question. does this mean all other codex other than MPEG2 can be networked? if not, which ones are and which ones aren't? use the shortest list =).
Edward Troxel November 7th, 2005 03:18 PM
You CAN use network rendering to tell another computer on the network to render the file to MPEG2. However, you do not want MULTIPLE computers rendering a single video to MPEG2. See here for more details:
http://www.sonymediasoftware.com/for...ssageID=277103
Here's some interesting info:
http://www.sonymediasoftware.com/for...ssageID=371431
Yi Fong Yu November 7th, 2005 10:13 PM
thx4link =).
