crop an sd clip for pip in hd video
Well Its been ages sense Ive been here. Im trying to do something I did in the past and darn if I can figure it out today.
I have a sd wide screen shot that I want to place in my hd video shrunken up to go in top left corner. I get the two black bars on the side of the video and I want to cut them out mask them or something so I just seen the widescreen video with out the bars. Thank you for taking the time. |
Re: crop an sd clip for pip in hd video
Perhaps combine the pan/crop tool with the Cookie Cutter plugin.
you might have to adjust the video to be the same aspect ratio as your project... in the Pan/Crop Tool, right click on the image and select "Match Output Aspect".
Another way to do it is to use the pan/crop tool to crop it then render to a new track.
Edit: Then pan/crop it again to the desired size and position. |
pan/crop the clip to eliminate the black bars,
then use track motion to resize & position it on the screen? PIP would be on a track above the full screen clip. Maybe. |
3 Attachment(s)
Chris Young |
