-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Help match these two shots (https://www.dvinfo.net/forum/what-happens-vegas/536469-help-match-these-two-shots.html)
Lalo Alvidrez December 15th, 2018 02:47 PM
2 Attachment(s)
One shot is from 5d mark iv and the other is from a canon 30a. Want to match the 30a to the 5d in vegas. Any ideas?
Patrick Tracy December 15th, 2018 03:18 PM
Re: Help match these two shots
You could try Vegas Color Match.
Or open up the Vector Scope and RGB Parade and try starting with Levels or one of the Color Correctors (Primary or Secondary). [Edit] Also try Color Curves.
Seth Bloombaum December 15th, 2018 08:54 PM
Step 1 would be to use a color correction filter for white balance, and correct the 30d footage, which is much warmer than the 5d. Depending on the filter, there may be an eyedropper that you can use to target one of the white dresses.
Then I'd look at Patrick's suggestions. I've not used Vegas Color Match, but it could be very helpful.
Christopher Young December 16th, 2018 12:14 AM
1 Attachment(s)
What version of Vegas are you using?
This was a quick CC done in v16 to 16-235 levels with the addition of AAV ColorLab a free 64-bit CC plugin for Vegas.
AAV ColorLab
If you want the VEG file just shout out.
Chris Young
