-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   import Canon C300 files from hard drive? (https://www.dvinfo.net/forum/what-happens-vegas/518797-import-canon-c300-files-hard-drive.html)
Mike Calla September 9th, 2013 03:27 AM
Hi all,
Does anybody have a workflow for getting Canon C300 files into Vegas via CF cards dumped on a hard drive?
This weekend I'm shooting lots of footage for a doc...in a village...in China. So i can't be reading files from the CF card. I'll basically be shooting, and dumping CF cards on to my laptop hard drive while i continue shooting.
When i get home i need to get these files into Vegas - somehow??
the few tutorials i've read/seen have people reading DIRECTLY from the CF cards using Canons files XF File Utility!
mike
Nicholas de Kock September 9th, 2013 06:27 AM
Re: import Canon C300 files from hard drive?
Usually you just drag & drop the files onto your timeline? Doesn't get more complicated than that. You can also go File > Import > Media & select the footage. No special instructions necessary.
Mike Calla September 9th, 2013 08:29 PM
Hi Nicholas.
Unfortunately it does get more complicated! You are correct in that you can drag and drop to your bins or timeline however the C300 puts each video into its own folder, and that folder resides in another folder. So if I'm shooting a 30sec spot, it's easy enough to dig into a few folders, but if I'm shooting a doc with a few hundred gigs of data its A MASSIVE pita!!
Leslie Wand September 9th, 2013 09:30 PM
don't own a canon, but can't you simply point the xf utility to the drive?
Juris Lielpeteris September 9th, 2013 10:07 PM
C300 clips by Alister Chapman from Canon C300 and Sony F3 footage to download. | XDCAM-USER.COM opens with Vegas Pro 12
Mike Calla September 10th, 2013 12:51 AM
Hi Leslie, Unfortunately no, silly as it is, it must be pointed to a CF card, but thanks.
Hi Juris, I've actually already downloaded these clips a few days ago & they play quite well in Vegas at best/full even with CC and curves applied (on quad core 3ghz) and they KILL DSLR footage!
Unfortunately the Canon XF Utility doesn't even see directory. I appreciate the link though.
Anybody else have any experience with the C300 and Vegas.
I dread coming back with a thousand clips, going into each one folder by folder
doh:(
Juris Lielpeteris September 10th, 2013 01:31 AM
You can search for *.mxf and drag all its from the search window.
Mike Calla September 10th, 2013 02:31 AM
Hehe I could yes...I got about 5TB of mxf files on my raid though...
I guess I could sort by date created.
but that's a work around at best.
I'm heading on over to the c300 forum to see if any c300 shooters can help. But I'll post back next week after my shoot with the results of How-i-learned-to-stop-worrying-and-learned-to-import-c300-footage
Nicholas de Kock September 10th, 2013 06:34 AM
My EX1 did the same thing, different folders for every clip. All you do is search *.mxf in the search bar in Explorer once you're in the folder containing all the different folders. This will bring up the video clips which you then drag into Vegas. Vegas doesn't really have bins your timeline is your bin, having three monitors help for sorting footage on the timeline ;)
Mike Calla September 10th, 2013 09:25 PM
Thanks Nicholas,
BTW project media folders and media "BINS" really help for sorting footage too:P how do you identify/query different properties of clips if they are all on your timeline? Some of my projects have 2 or 300GB of footage I can't imagine Vegas can cope with that much footage on the timeline - it can hardly cope with that much footage in the bins, hehe!
Ok back to the main topic:
you and Juris both advocated the search and copy method, & that seems to be good for now
- I keep my copied C300 CF card data on an external HD (or separate from all my other mxf footage just for the sake of organising the search)
- i search that drive/directory by file format
- copy mxfs to their new home directory
- each lunch
That seems to be the most simple workflow!
Nicholas de Kock September 11th, 2013 12:41 AM
Thanks. True you're begging Vegas to crash with that much footage. Mind you I easily load 250Gb of footage onto a timeline. I then sort it from there & split (Save As) the project into smaller project sections eg. Day 1, Day 2 and once I'm done with the edit combined all the section together.
Quick note: It's not necessary to copy them into a new directory if you want you can just drag them onto the timeline from the search.
Roy Feldman September 11th, 2013 03:25 AM
In the canon utility, under 'edit' is a selection to export just the MXF files, it can be set to join any clips that were spanned. Quickest way I've found.
Mike Calla September 11th, 2013 03:32 AM
I know, it's just part of my work flow since Vegas was a DAW. I'll rename and renumber them etc before I load them into Vegas
Thanks Nicholas
Mike Calla September 11th, 2013 07:27 AM
Hi Roy, sorry, on my mobile and missed your post.
Does the XF utility need to read from the CF card? Or can it read from a directory the CF card contents have been copied to?
Roy Feldman September 11th, 2013 08:40 AM
I can't say, I forgot to mention it is also possible to re-name with sequence thru the Canon XF
