-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Vegas Pro 12 (https://www.dvinfo.net/forum/what-happens-vegas/510893-vegas-pro-12-a.html)
Edward Troxel October 12th, 2012 08:58 AM
Re: Vegas Pro 12
Jeff, it has been working for me. I can't say I've really pushed it that hard, though. I did notice last night that it didn't preview on my external monitor via a DV/Firewire connection. Pro 9 does fine on that machine and I didn't double-click 10 or 11 last night.
I'm still not sure why people are vilifying Titler Pro. It's working on the majority of systems. On the ones where it is not, we're trying to find the conflicts. I can't tell you how many times someone has reported a crashing issue, we had them upgrade their video driver, and suddenly all is now fine. I've heard of another case where someone was using a tablet input device. Disabling that driver allowed Titler Pro to then work. There's also been a couple of cases where it worked fine when the Titler dialog was on the main monitor but not on a secondary monitor. So, yes, I know some people are having issues but also know they are becoming fewer and fewer. And in those cases, I'm sure it's directly related to something in their system setup - it's just a matter of searching and searching until the conflict is found.
Jeff Harper October 12th, 2012 09:34 AM
Re: Vegas Pro 12
Thanks Ed. It looks like a very nice upgrade. Can't use it now, but will buy it for sure. I always do.
Nicholas de Kock October 12th, 2012 11:03 AM
Re: Vegas Pro 12
Jeff the trail I'm running seems to crash just as much as 11 (every few minutes), not sure if I'm going to upgrade still making up my mind.
Jeff Harper October 12th, 2012 11:36 AM
Re: Vegas Pro 12
Nicholas, 11 has been 100% stable for me since the next to last update, before it was not stable.
Recently I changed my RAM timings and then Vegas began crashing a LOT. I changed my timing back, and now it's fine.
Edward Troxel October 12th, 2012 11:47 AM
Re: Vegas Pro 12
I honestly believe a lot of people having issues with Vegas and/or the NewBlue GPU Accelerated products are having system specific issues. Changing the RAM timings could definitely affect it.
Jeff Harper October 12th, 2012 01:29 PM
Re: Vegas Pro 12
What's funny about my settings was that I have expensive memory known to work at 9-9-9-27, which are the timings that gave me issues. I was previously at a conservative setting of 10-10-10-30 and had just forgotten to adjust to the faster, normal speed after I had installed the RAM.
9-9-9-27 shouldn't have, in my feeble mind, caused crash issues with Vegas, but apparently it did. It's not a big deal, the slower timing is unimportant and does not matter to me, Just a quirky thing I think.
Nicholas de Kock October 12th, 2012 02:26 PM
Re: Vegas Pro 12
Not sure what the problem is Jeff, I save all the time every other minute, crashing is normal to me I've given up trying to find an answer. The latest update on Vegas 11 helped considerably but still not stable. When grading with curves I experience a lot of instability but it's mostly random hard to pin point. The only thing I still do in Vegas is edit, I render to Cineform and do my transcoding and mastering in Adobe. As soon as Adobe Premiere adopts a free roaming timeline similar to Vegas (which I hope will happen one day) I'll switch. These days I even master my audio in Adobe Audition, much more powerful of the bat & Encore kicks DVD Architect ass.
Jeff Harper October 12th, 2012 02:31 PM
Re: Vegas Pro 12
Encore is a superior DVD authoring tool, very nice product.
Tom Roper October 12th, 2012 03:06 PM
Re: Vegas Pro 12
Me too. Grading with curves, but also color corrector, brightness and contrast and others. It's actually easy to pinpoint, Vegas.
Buba Kastorski October 15th, 2012 07:02 AM
Re: Vegas Pro 12
i tried to open in V12 fairly complicated project saved in vegas 11, multiple audio and video tracks, but version 12 opened it as a single audio and single video track with one continues video and audio event,
how do i keep the project structure from version to version?
Nicholas de Kock October 15th, 2012 07:48 AM
Re: Vegas Pro 12
Vegas 12 should open Vegas 11 projects exactly the same way there shouldn't be any difference. Sounds like you nested the project into Vegas 12?
Graham Bernard October 15th, 2012 09:05 AM
Re: Vegas Pro 12
Yup, sounds like a Nest to me. Did you Drag the Veg onto VP12 Timeline?
Grazie
Renton Maclachlan October 15th, 2012 08:20 PM
Re: Vegas Pro 12
But apparently you can't open v12 in v11...correct?
Graham Bernard October 15th, 2012 09:27 PM
Re: Vegas Pro 12
Correct. Never been able to go backwards to an earlier Number release of Vegas: 12 into 11; 11 into 10; 10 into 9.... And so on.
Grazie
Buba Kastorski October 16th, 2012 06:42 AM
Re: Vegas Pro 12
Grazie
no, I oppened the project, and i tried all possible ways, "open with", file>open, double click from vegas Explorer, but i do get it like nested project every time, is there setting somewhere?
