-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Simple Mask???? (https://www.dvinfo.net/forum/what-happens-vegas/507145-simple-mask.html)
Jim Andrada April 20th, 2012 09:22 PM
Simple Mask????
I have a clip with a completely black background - actually an unlit space. There is a red exit sign showing in one spot. Camera is locked down and nothing in the vicinity of the sign is moving
Logically all I want to do is copy a small piece of the background and move it over and paste it on top of the red sign.
Just a simple static mask would do the trick I think
David Jimerson April 21st, 2012 08:29 AM
Re: Simple Mask????
You can do it with a bezier mask or cookie cutter and track motion.
Duplicate the clip, place it over the original clip, use the bezier mask or cookie cutter to create a rectangle, then use track motion to move it over to the sign.
Bezier mask will probably work better, as it's more precise, and you can control the feather better. Chances are, the "black" is not even throughout the frame, so taking a rectangle from one part and moving it to another will reveal a slight difference; being able to feather the mask will keep it from being an obvious, pasted-in rectangle.
Jim Andrada April 21st, 2012 09:24 AM
Re: Simple Mask????
Thanks much - I'll give it a try.
Ian Stark April 22nd, 2012 10:59 AM
Re: Simple Mask????
David's answer is spot on, of course, and that's exactly how I would do it. But if you're results aren't perfect and that masked area is still obvious I would then try taking a still of the frame (best/full), removing the exit sign in gimp/photoshop etc (where you have infinitely better drawing/cloning/repairing etc tools), and replacing the video event on the timeline with the edited still image.
