-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   My system and EX3 images (https://www.dvinfo.net/forum/what-happens-vegas/506128-my-system-ex3-images.html)
Geoff Jak March 15th, 2012 11:19 AM
I am about to shoot a project on a Sony EX3 (at 35Mbps if the system will handle it) and need to know if my system can handle the images when editing. Total hours of images will be approx 3 hrs edited to about 40 mins.
Config is -
Vegas 9d
Processor : Intel(R) Core(TM)2 Duo CPU T7300 @ 2.00GHz
Memory : 1024MB(Speed 667) - strange...I know i have 2 gigs installed. Betta look under the bonnet.
Mother Board : Tahoe
Windows Version : Microsoft Windows 7 Ultimate Service Pack 1
Installation Date : 2011-02-04
Monitor : Generic PnP Monitor
Video Adapter : ATI Mobility Radeon HD 2400 XT
Disk Drive : WDC WD2500BEVS-22UST0 ATA Device(232GB, IDE)
Drive 2: WD 1 Gb SATA
DVD/CD-ROM Drive : MATSHITA DVD-RAM UJ-850S ATA Device
Is this going to cut the mustard or do I need a heftier system.
Thx in advance.
Leslie Wand March 16th, 2012 12:29 AM
Re: My system and EX3 images
short answer no.
you'd probably edit hdv ok, avchd might prove painful, 35mbps mxf is pushing it over the edge. imho.
Stefanos Lampridis March 16th, 2012 10:16 AM
I can't see it happening, sorry. You need a new system.
Geoff Jak March 16th, 2012 10:39 PM
Ok, thanks for the advice guys.
Stefanos Lampridis March 17th, 2012 02:11 AM
Just remember don't go over the edge.
Choose wisely your components. ANY pc built will be old in 1 year and a half or two.
There are a lot of topics in here about pc components, have a look and go from there.
Hope it turns out ok for you.
Geoff Jak March 17th, 2012 09:13 AM
Ok so I got the message I cant import @35mbps cos my system is not powerful enough...so...can you recommend the best bit rate and format.
I can record (in PAL land) at HQ and SP1080/50i / and HQ 1080/25p then other record option are HQ720/50p / 25p.
Which one to go for?
If I record in the highest setting then when exporting to Vegas 9e downconvert to a workable setting that my system can hanle then that would be fine. The program needs to be screened on a HD TV.
I see there are heaps of options in Vegas as well.
As usual, I have lots to learn. Thx
Colin Rowe March 17th, 2012 10:03 AM
It will edit. I used a core2duo 2.4 with 2gb ram for EX1 footage for over a year, got a bit sticky at times, ie, multicam etc, but got the job done. I now use an Acer laptop, (i5 with 8gb ram) handles anything I throw at it, and only cost £400. At that sort of price it makes upgrading a no brainer
Mike Kujbida March 17th, 2012 10:07 AM
Geoff, if you're using Pro 9, try using the free Proxy Stream script to downconvert your files to a format that's easier to edit.
Gilles has a lot of other excellent scripts on there (I use Open In Graphic Editor all the time) so definitely check them out too.
Here's the readme file from the script.
THE CONVERSION TAB.
The “directory” area is to select the source files (input) and the proxy files (output) directory.
The “Files to convert” area is to list the media located in the source files directory with one of the selected extension of the “Media Type” area.
The name of the Proxy file is based on the name of the source file + the new extension (for example, “Movie.mpg” become “Movie.mpg.AVI”)
THE SWITCH TAB.
This tab is to switch between the Proxy and Source files in a project.
Proxy and Source files must be stored in the same directory.
What's new in 1.5b:
-Proxy Stream 1.5b works with VP9 only.
-Added ability to anable/disable Switches (Resample, Maintain Aspect Ratio and Reduce Interlace Flicker).
-Proxy files have same creation time and last write time attributs as source file. So you can use SVDTS script from Paavo Jurvelin with proxy files ( see at svdts.com )
Geoff Jak March 17th, 2012 10:10 AM
Wow! thats pretty amazing...and encouraging Colin.
So what settings to use if I start out at 1080/50i...or do you recommend starting at another setting.
Also what setting to use for render. There are heaps of render to possibilities in Render As. Cheers
Geoff Jak March 17th, 2012 10:22 AM
Brilliant Mike! Thx
I'll definitely have a go at this.
How to install the script pls.
So does that mean I can record at the highest setting in the Sony EX3, edit in a proxy, then the original images are rendered, without those large originals being imported to the timeline?
Mike Kujbida March 17th, 2012 10:36 AM
Geoff, drop the dll and png (the script icon) files into your Pro 9 Script Menu folder.
Start up Vegas and the script should be there. Add it to your toolbar if you want to.
Once that's done, run the script. It's very user-friendly and I don't see you having any problems with it.
Enrique Orozco Robles March 17th, 2012 12:33 PM
"you'd probably edit hdv ok, avchd might prove painful, 35mbps mxf is pushing it over the edge. imho."
...I have to disagree... I've been with Vegas since Sonic Foundry ... drag and drop 35mbps mxf files and edit them is as easier as AVI-DV in those good old days.... better than HDV & AVCHD ....
...just ADD memory (RAM) to your system.......
good luck
Dennis Vogel March 17th, 2012 02:25 PM
I've never built my own computer but I hear folks speak highly of PC Perspective (PC Perspective | Your #1 Source for PC Hardware Reviews, News and Information!) for info on hardware for DIYers. Specifically, go to the "HW LEADERBOARD" tab at the top and you'll see 4 pre-configured systems depending on your budget and needs.
FYI, I have no financial or any other relationship with pcper.
D
Geoff Jak March 17th, 2012 04:41 PM
I've read all your advice over the past 24 hrs and am impressed with the response.
Off to the shoot soon and can now go in there confidently that I will come out of there with pics that will edit well on my system. It's a load off my mind I can tell you.
I will come back to this thread in a couple of weeks and let you know how the edit went.
Thanks to you all Geoff
Geoff Jak March 17th, 2012 06:55 PM
One more thing....when exporting the scenes from XDCAM Browser 1.0.0.1 I have exported to MFX for NLE. Is that the right one.
The output will be DVD.
There are a bunch of other export options and I dont really know which to use. Thx
