-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Sony Vegas Pro 11 update (https://www.dvinfo.net/forum/what-happens-vegas/502210-sony-vegas-pro-11-update.html)
Jeff Harper November 1st, 2011 09:46 AM
Sony Creative Software - Download: Vegas Pro 11.0
Fastest Update I've ever seen from Sony.
Dror Levi November 1st, 2011 09:47 AM
sony Vegas pro11 update
it says it will fix some GPU bugs.
I really hope it will.
Ian Stark November 1st, 2011 09:57 AM
Re: Update Vegas 11
Annoyingly the release notes page seems to be unavailable. Anyone able to view it and if so could they kindly copy and paste the contents here? Thanks.
Edward Troxel November 1st, 2011 10:01 AM
Re: Update Vegas 11
If you install it, there should also be release notes in the Vegas 11 folder inside Program Files. Perhaps you could pull it up there and post the listed changes?
Ian Stark November 1st, 2011 10:08 AM
Re: Update Vegas 11
Done!
Notable fixes/changes in version 11.0 (Build 425)
Enabled GPU acceleration for NVIDIA GPUs with Compute Capability prior to 2.0 when using driver 285.62 or newer. See this Web page for a list of Compute Capability levels for various NVIDIA GPUs: | NVIDIA Developer Zone.
Improved performance for GPU-accelerated video processing for certain GPU and chipsets.
Improved performance for GPU-accelerated Page Loop, Page Peel, and Page Roll transitions.
Improved performance for GPU-accelerated Noise Texture generator.
Improved performance for OFX media generators that are not animated.
Added support for 422 profile in MainConcept MPEG-2 custom templates.
Changed the default field order for MainConcept MPEG-2 NTSC DVD templates to upper first (which is more common and matches more source media).
Fixed an issue reading AVI files created by Autodesk 3ds Max.
Fixed an issue that could cause silent audio on certain long MP4 files.
Fixed an issue that prevented MainConcept MPEG-2 custom templates from Vegas Pro 10 from functioning correctly.
Fixed an issue that could cause MainConcept GPU-accelerated AVC rendering to fail in some cases.
Fixed an issue where previewing Cross Effect in the Transitions window could make the preview thumbnails incorrect for subsequent previews.
Fixed a Y-axis inversion in the Mirror plug-in.
Fixed an issue with certain settings of the Cookie Cutter plug-in not matching previous version.
Fixed a freeze that could occur when rendering a 32-bit floating point project with certain FirePro GPUs.
Fixed an issue that allowed compositor plug-ins to be dragged to events.
Fixed an issue that allowed more than one compositor plug-in on a track.
Fixed an issue with Color Corrector and Color Corrector (Secondary) color wheel interpolation when crossing the zero-degree line.
Fixed an issue that could cause Media FX to be dropped when relinking media.
Fixed an issue that could produce incorrect output for the Sepia plug-in when used on images with transparency.
Fixed an issue with the Levels plug-in that could produce incorrect results in some cases if Channel was not set to All.
Fixed an issue that could cause artifacts for high settings of the Feather control when processing was not GPU accelerated.
Fixed an issue that caused Stereoscopic 3D Adjust floating windows to be transparent when processing was GPU accelerated.
Fixed an issue that could cause an error when rendering to certain MainConcept MPEG-2 templates.
Fixed Cookie Cutter plug-in shapes for projects with nonsquare pixel aspect ratios.
Fixed an issue with Defocus, Glint, Rays, Soft Contrast, and Starburst when used with images with alpha channel or transparency.
Fixed an exception error that could occur with certain editing scenarios in the ProType Titler.
Fixed a crash that could occur when using the RE:Vision Effects ClampTime plug-in.
Fixed a case where a keyframe could be created for an incorrect parameter when using the Custom view of an OFX plug-in (such as Color Corrector).
Fixed an issue that could cause Paste Event Attributes to use the wrong event’s attributes when the source events were grouped.
When using the Upload to YouTube dialog, tags must be at least two characters long. The Upload button is unavailable if your tag is shorter than two characters.
New Features in Version 11.0
Video
GPU-accelerated video processing (please see System Requirements for information about supported hardware).
New Titles & Text plug-in.
Improved usability for the ProType Titler.
Added a new Star Wipe transition.
Added a new Radial Pixelate video plug-in.
Added per-parameter keyframes for many video plug-ins.
The Transitions, Video FX, Media Generators, and (new) Compositors windows all include folders to group plug-ins and a search box to help you find plug-ins easily.
The Stabilize plug-in has been simplified and improved.
The Stereoscopic 3D Adjust plug-in now includes Floating Windows controls to allow you to mask the edge of the video frame to compensate for screen-edge violations.
Added a Stereoscopic 3D depth control to the Cookie Cutter effect, as well as Cross Effect and Iris transitions.
Support for NVIDIA 3D Vision on single-display systems using the Windows Graphics Card device (available in Preferences > Preview Device).
Event Pan/Crop is now integrated into the Video Event FX dialog.
Audio
Improved usability for the Mixing Console.
A simplified Master Bus window provides you with a streamlined view of your project's master output.
Workflow
Sync links provide an additional method of keeping events synchronized: a linked event retains synchronization when the event it is linked to is moved but can be moved independently.
An updated Render As dialog streamlines the rendering process and makes it easy to manage your favorite render templates.
Integrated Upload to YouTube.
Formats
MainConcept AVC/AAC improvements:
Added MP4 templates for Internet distribution.
Added an Enable progressive download check box to the Video tab of the Custom Settings dialog to allow your videos to begin playing during download.
Added support for GPU-accelerated rendering.
Added support for RED EPIC® clips.
3.0 Known Issues
The Windows Media Audio 9 Voice codec is not included with the Windows Media Player 11 update. If you've installed Windows Media Player 11, rendering to Windows Media Audio 9 format will produce an error. For more information, please refer to Knowledge Base article 932390 on the Microsoft Help and Support site.
If you are printing a rendered file to HDV tape, the file must precisely conform to the target HDV device and file type requirements, or the print-to-tape operation will fail. Rendering using the provided HDV MPEG-2 render templates—unmodified in any way—is required to successfully print to HDV tape.
Vegas Pro templates for rendering multichannel audio in .wav/.wav64, .avi, and .mxf formats may be visible in other Sony Creative Software Inc. applications that do not support multichannel audio. Using these templates in other applications will not produce the desired result and should be avoided.
Under some uncommon conditions on multiprocessor machines, you may encounter stability problems when using some Waves 5.2 plug-ins. In most cases, the stability issues can be resolved by clearing the Enable track buffering check box in Vegas Pro 10 (Options > Preferences > Audio Device).
You may not be able to render files larger than 4 GB using some combinations of settings in the Sony AVC encoder.
If you have multiple Sony applications (such as ACID, Sound Forge, CD Architect, etc.) installed, uninstalling other Sony applications may cause your audio plug-ins to be removed from Vegas Pro. To restore your audio plug-ins, uninstall and reinstall Vegas Pro.
When the Show Video Monitor button in the Trimmer window is selected, video that you preview from the Vegas Explorer and Media Manager windows is played back in the Trimmer. Because the Trimmer is placed in the same window dock as the Explorer and Media Manager, you will not see your video preview. To preview Explorer and Media Manager video, you can drag the Trimmer to a new dock group, or you can turn off the Show Video Monitor button to preview in the Video Preview window.
The Step Forward and Step Backward buttons in the Capture window are not supported by all HDV devices.
If your project contains still-image sequences or segmented .r3d files, do not select the Copy media with project check box in the Save As dialog. Some frames or segments may not be saved when this check box is selected.
The following features are not available in the 64-bit version of Vegas 11.0. If you need to use the following features, you can share projects between 32- and 64-bit versions of Vegas 11.0 installations, performing editing as needed in 32-bit Vegas 11.0 and finishing the project in 64-bit Vegas 11.0:
Rendering templates created in 32-bit Vegas 11.0 are not available in 64-bit Vegas 11.0.
Gracenote support is not available.
AAF import and export are not available.
Third-party plug-ins will work only if they are 64-bit plug-ins. Please check with the plug-in vendor for available updates.
Installing driver 2.21 for the PDW-UI XDCAM drive can prevent Vegas from starting. Uninstalling the driver or upgrading to version 2.3 will resolve the issue.
If you're running two instances of Vegas Pro, external control devices are available only to the first instance of the sofware.
When using the Stereoscopic 3D Graphic Card as your preview device with an nVidia 3D Vision for Quadro or 3D Vision Pro setup on a Windows Vista machine, the 3D output may stop when opening another window (such as a video FX property page). If this occurs, please make sure you have the latest graphic card driver and 3D Vision USB driver installed. If installing the latest drivers does not fix the problem, try switching the primary and secondary monitors. There is also a known issue where content on the main window will flicker. This can be fixed by moving another window over the portions of the window that are flickering and then closing the overlapping window.
We recommend Windows 7 for nVidia 3D Vision for Quadro setups.
Rendering CineForm Neo3D files requires CineForm NeoHD, Neo4K, or Neo3D 5.1 (or newer) or GoPro-CineForm Studio, Studio Premium or Studio Professional. The CineForm Neo Player is not compatible with other CineForm products. Do not install Neo Player if you have another CineForm product installed.
Version 5 of the AJA device drivers support 64-bit versions of Windows 7 only.
CEA608 and CEA708 closed captions are supported over HD-SDI on AJA cards only. Line 21 captions are supported on AJA and DeckLink cards.
Right-clicking a media file and choosing Edit Source Project fails to load the project path saved in the media file for media rendered using the following settings: MainConcept AVC/AAC and Sony AVC (Memory Stick templates only).
OpenCL GPU rendering is not available when using AMD Radeon Catalyst driver 11.3, 11.4, 11.5, and 11.6. Please use driver version 11.7.
In order for some devices to appear in the Device Explorer window, you may need to change the device’s USB Connect setting from Automatic or MTP to Mass Storage.
The Tools > Burn Disc > DVD with Menus and Tools > Burn Disc > Blu-ray Disc with Menus commands are unavailable if DVD Architect Pro is not installed.
If you want to use RAW camera files in your project, the Microsoft Camera Codec Pack will allow you to view RAW camera files and add them to the timeline.
Using the Blackmagic HD Extreme with the Blackmagic ASIO Driver can cause Vegas Pro to hang.
Jeff Harper November 1st, 2011 10:08 AM
Re: Update Vegas 11
Drori posted re: update apparently before I did, didn't see his post, sorry! I think it showed up later, but he posted first.
I've downloaded it, the original it working pretty well for me so far, so I might wait to see what you guys think before I do it!
This looks like a worthwhile update, for sure.
Chris Barcellos November 1st, 2011 10:09 AM
re: Sony Vegas Pro 11 update
Can you post the notes for the update.
Ian Stark November 1st, 2011 10:13 AM
They're in the competing thread! http://www.dvinfo.net/forum/what-hap...egas-11-a.html
Chris Hurd November 1st, 2011 10:17 AM
Re: Sony Vegas Pro 11 update
Duplicate threads now merged.
Dror Levi November 1st, 2011 10:53 AM
for some reason I am not able to download the 64 bit but only the 32 bit,
Do you know of any other page to download the 64bit.
This is what i am getting
"The page you are looking for might have been removed, had its name changed, or is temporarily unavailable."
Mike Kujbida November 1st, 2011 11:00 AM
Dror, a lot of users are downloading it right now so keep trying and you'll get it sooner or later.
Ian Stark November 1st, 2011 11:05 AM
Yes, my download took something like 8 minutes for the 64 bit but only around 45 seconds for the 32 bit (100Mbps broadband), suggesting the former is popular!
p.s. thanks Chris.
Jeff Harper November 1st, 2011 11:31 AM
When I opened updated version, it crashed right away, but since then it's working fine.
Mike Kujbida November 1st, 2011 11:50 AM
http://download.sonycreativesoftware....424_32bit.exe
http://download.sonycreativesoftware....425_64bit.exe
Robin Davies-Rollinson November 1st, 2011 12:28 PM
Runs really sweetly now. Id upgraded my graphics card especially for version 11, but there were still a few issues. Now, hopefully, they seem to have gone away - and the NewBlue Pro Titler really rocks!
