-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Time lapse from GoPro (https://www.dvinfo.net/forum/what-happens-vegas/498060-time-lapse-gopro.html)
Jim Andrada July 4th, 2011 12:58 PM
I've been trying to catch a bobcat with a GoPro - more exactly, catch a PICTURE of a bobcat that strolls by here most mornings.
I set the camera to record a photo every 2 seconds and now have several thousand frames to review
I can select all the frames and Vegas brings them all to the timeline, but seems to want to play them at 2 seconds apiece.
How can I get it to play them at 29.27 fps to scan for the bobcat?
Mike Kujbida July 4th, 2011 01:08 PM
Re: Time lapse from GoPro
This assumes that they're in a separate folder and that each image is "properly" sequentially numbered (i.e. image001.jpg, image002.jpg, etc.)
Do an "import media" as usual and browse to this folder.
Click on the first image in the sequence and then click the "Open still image sequence" box at the bottom of the screen.
Vegas will import all your images as a sequence that can be dragged to the timeline.
Jim Andrada July 4th, 2011 01:22 PM
Thanks much.
I'll give it a try
Edit Worked fine but no Bobcat. My wife saw the cat today but camera wasn't set up
Cedric Cornell July 5th, 2011 10:01 AM
Did this with a bird table, 2000 pics and only 2 frames with a bird!
Did ttis with a gopro, good fun.
Jim Andrada July 5th, 2011 12:16 PM
Only problem I've had setting up the time lapse was the difficulty of framing the shot..
Set up the camera, take photo, hook it to the PC, look at the photo, adjust position (fortunately using s quick release tripod plate) and repeat. 14 times!
I just ordered the LCD back for it to make it easier next time (f there is a next time)
Anyhow I'm just starting to scan the 8k photos from this AM
Maybe the Bobcat will leap out at me.
