AVI file (converted from FLV) imports as audio track only in Vegas
I have an FLV file that someone gave me to do a couple of simple edit corrections.
I converted the FLV file to an AVI file using a free program called Freemake Video Converter. The file converted successfully and I can play the AVI file using any video player. When I attempt to import the file to Vegas 9 and place it on the project timeline - the file appears only as an audio track, without a video track. I've tried importing both by going to File > Import > Media... and also by simply drag & dropping the file onto the timeline. Both methods end up with the same problem. The file shows up as sound only and there is no video track... although clearly there is video (which I can see when playing the file with Windows Media Player or VLC Media Player). Anyone know what could be wrong? |
Re: AVI file (converted from FLV) imports as audio track only in Vegas
It's probably a codec that Vegas won't read, like DivX.
You might want to download GSpot and find out the codec. GSpot Codec Information Appliance |
hi thanks for the reply.
GSpot says: http://i55.tinypic.com/24crvia.jpg If someone has a suggestion for a different program to use to convert the FLV file... I'd be happy to hear it. So far I've tried XMedia Recode... the outcome was bad quality, although the video was visible unlike Freemake Video Converter. |
To use an AVI in Vegas, the file needs to be encoded using a codec for which you have a Video For Windows version installed. That the file plays using a video player indicates that you do have a codec installed, but it is a directshow based codec.
Two things you can try: locate a VFW-based x264 codec and install it. Or - try reencoding to another VFW codec. I'd suggest installing the Lagarith codec and encoding to that - that will easily get your video into Vegas without any intermediate loss in quality. Once in Vegas, you can output to whatever Vegas has. |
Hi Adi,
I have done it many times using "Real Player" converter Just download the free one and find the converter to convert to avi. . |
Try HandBrake on the FLV then import the m4v file that generates into Vegas. It's open-source and not riddled with adware. Most of all other FLV converters are riddled with ads and possibly spyware.
HandBrake |
VLC also is open source, free and will do the conversion.
VideoLAN - Official page for VLC media player, the Open Source video framework! |
Okay. It was a codec issue. I've recently made a clean installation of Windows XP. I used to just install the K-lite Codec pack, but someone on this forum once advised me not to install codec packs on computers on which I intend to do video editing. So this time I followed his advice.
I was missing the h.264 codec, so I installed it and now the file works fine in Vegas. Side-stepping a bit from my original topic... since the whole codec issue has always been somewhat confusing for me... and since I'm not going to be simply installing K-lite codec pack, I'd really appreciate it if you guys could point out a number of codecs I should definitely download and install for future use. So far I've installed Lagarith, Xvid and the h.264/AVC codec. Thanks! |
Codec packs have been known to do nasty things to editing systems and, in some cases, overwrite already installed good codecs with their garbage ones. Quote:
Okay, I have GSpot so I'll do as you suggest. Thanks for the tip Mike. :)
Ive tried a few times with no luck at all, most times I end up with a small text file, or nothing at all. |
Regarding which codecs I should install...
I then edited in Vegas. Now I want to render two files: 1. A master file while preserving the quality as best I can 2. A compressed file for using on the web When attempting to make the master file I selected avi for file format and the lagarith codec, as it is lossless. For audio codec I selected PCM (uncompressed), figuring that would not damage the audio any more that it already is. The render was successful, but when I play it on Windows Media Player there is no sound. Is this because the PCM codec is not installed on my system? I googled PCM audio codec, but couldn't find any convincing links for where to download and install this from. On a different subject... Quote:
another for wanting to know converting in vlc!?
actually, haven't really needed to do any conversions outside of handbrake recently, but i do remember trying to convert something in vlc and ending up with txt files..... |
To convert using VLC:
1. In the media menu select Save/Convert 2. In the Open Media dialog click the Add button to add you video file (I've never gotten multiple files to work). 3. Click the Conver/Save button. 4. Select your output options. I've only used H.264 for converting FLV files. Next time I need a conversion I'll try Handbreak for comparison. |
Thanks Victor...
Anyone has any suggestions how to get PCM encoded audio to work with Windows Media Player? From what I've researched, I understand it is supposed to be installed by default on Windows systems... so I'm not sure what is wrong. Please help... |
| All times are GMT -6. The time now is 05:12 AM. |
