Sony YUV codec
I`m trying to figure out what should be the best codec choice within Vegas (9, 10) to render a timeline to a file that is going to be transcoded to a HDCAM tape.
Regarding this subject, I wonder why (what kind of projects) should I render to Sony YUV and Sony 10bits YUV codecs - I didn`t find the answer in Vegas 10 manual. Thanks |
Re: Sony YUV codec
I did some research awhile back with Vegas 9.0 comparing the Sony YUV
codec(s) and other lossless YUV codecs like HuffyUV and Lagarith and studying the final output files with a YUV native waveform monitor. I believe that when you use the Sony YUV codec you are guaranteed that Vegas will be converting RGB to YUV using it's internal RGB->YUV conversion routine. One of the advantages of this is that if you have YUV input files like DV or MPEG2, the rounding errors that occur due to YUV->RGB->edit->RGB->YUV are minimized since the conversion algorithms are "matched" in some sense. The final video is slightly superior from the standpoint of a pixel peeper that analyzes histogram distributions and rounding errors. I also found that Sony YUV 10 bit was slightly smoother and nicer than the regular 8 bit version but if you don't have 10 bit output it isn't worth the trouble. If you use other YUV codecs like HuffyUV or Lagarith, Vegas always feeds RGB to those codecs and it is up to those codecs to internal convert RGB->YUV. Since this algorithm is not matched to the YUV->RGB conversion algorithm, a slight amount of rounding error is introduced to the final output. In Vegas 9.0, the cineform codec (I think) was in the same boat as HuffyUV so a slight amount of rounding error was introduced. In Vegas 10.0 I see that Sony has completely customized the cineform writing functionality so I bet that it is using the optimal conversion strategy. To answer your question, if you can write SonyYUV to hdcam without doing a color conversion then SonyYUV is what you want. If you are feeding the hdcam deck with a blackmagic card you might need to convert the SonyYUV to the blackmagic lossless codec with a lossless transcode. I think the blackmagic utility can do this or virtualdub can. |
Re: Sony YUV codec
Thank you very much Dustin.
It`s the first time I will (probably) do a HDCAM copy so I don`t kow if I can write SonyYUV to hdcam without doing a color conversion, becouse I haven`t argued the finishing house about it - I know they are used to convert with Aple`s PRORES. So I wonder if Sony YUV would be compatible with other editing systems beside Vegas to do the convertion. The codec I have my project rendered / masterized at this moment is (Quicktime) MJPEGA and I gess there would be a better codec to make the master to convert to HDCAM, what seems to be Sony YUV. Thank you again |
Re: Sony YUV codec
An avi file rendered with the SonyYUV 8bit codec is basically just raw uncompressed
YUV pixels. Rather than uncompressed RGB it is uncompressed UYVY. It is slightly smaller than uncompressed RGB but it is still uncompressed so you need hard disk space. It is a much cleaner codec that MJPEG but your mileage may vary. The minor quality increase from avoiding a compression generation might not be noticeable. |
Re: Sony YUV codec
Thank you Dustin.
Regards |
Re: Sony YUV codec
Ron, since the post house is FCP, you might want to consider the free Avid DNxHD codec.
Both of you you will have to have it installed on your system. Avid - Avid QuickTime Codecs 2.3.4 Specifications |
Re: Sony YUV codec
Thank you Mike.
After I instal the free Avid DNxHD codec in my system, how will I find it in Vegas 10D to do the render? Will I find it in "Save as Type: Quick time 7 (*.mov)? |
Re: Sony YUV codec
That's correct Ron.
After doing that, click the Custom button, in the Video tab, choose "Avid DNxHD codec" in the Video format dropdown box, click Configure and then choose from the dizzying range of options. I don't use the codec myself but I know some folks on here do as well as users in the Sony Vegas forum. Hopefully someone can advise you on the right choices to make. |
Re: Sony YUV codec
Seeing as Lagarith supports RGB (as well as RGBa), Vegas is claimed to use RGB internally, and colorspace conversions are claimed to be a 'bad thing'... Why would anybody bother to even consider using Lagarith's YUV colorspace? RGB works fine, and RGBa is the way to go if you're doing any CGI compositing. |
Re: Sony YUV codec
Hi
It's very confusing all this, my current work flow is:
The slight snag with the above method, and I'm not sure exactly why, but output to Lagarith from Sony Vegas has a different colour range with washed out blacks and dull highlights, so in the AVISynth script during the conversion to YV12 I tell it to use the PC.709 colour matrix which corrects this. Outputting YV12 direct from Sony Vegas is the same, washed out so I would still need a conversion in the AVISynth script. So now comments here about the Sony YUV codec got me thinking maybe that would be a better option. When I use the Sony YUV codec, there is no colour space issues, i.e. blacks are blacks, why is that? The snag though with the Sony YUV codec is I can't get this read with AVISynth correctly, it can be opened using 'Rawsource' but I don't know the correct parameters to pass for it to work correctly. Also wouldn't this still mean a conversion from YUV to YV12 is needed for X264. Maybe this is better than the RGB conversion to YV12? Having a play around I've since discovered I can output directly to YV12 (or RGB) to the Lagarith codec without colour space issues so blacks are black, by selecting under Project properties the Pixel format 32-bit floating point (full range). What is this changing and should I do this? Would this be a better option, use full range, output as YV12 to Lagarith so this would mean Sony Vegas is doing the colour space conversion and sending YV12 to Lagarith, or is Vegas still sending RGB and it is just the codec doing the conversion? I think my main concern is with the colour space issues (0-255, 16-235) and if converting between them is potentially losing colour information, and is using the 32-bit floating point full range option a good idea when outputting from Sony Vegas, it certainly seems to correct the issue with regard to the shifting black levels. Regards Phil |
Re: Sony YUV codec
Hi
Did some tests: Sony Vegas to Lagarith YV12 then to X264 shows a very slight shift in colours compared to the original. Sony Vegas to Lagarith RGB then via AVISynth to YV12 to X264, absolutely no shift in colours, identical to the original. It seems to make no difference if I render for 32bit 'video range' or 'full range', except for video range I need to ask AVISynth to convert to YV12 using the PC.709 matrix which puts the levels back correctly, the final results are identical with nothing seemingly getting lost with the stretch then compression of the colour space. Think I will stick with this workflow of Lagarith RGB out unless anyone has any other insight. Regards Phil |
Re: Sony YUV codec
will have to convert to YUV and when you do, you may want to most accurate conversion possible if you are trying to squeak every last ounce of color rendition quality out of your system. IF Vegas could render YUV straight into Lagarith, then Lagarith would be a great lossless YUV codec that you could then feed into a high end MPEG-2 encoder like Cineform or whatever. Quote:
as RGB then you may as well output in RGB from Vegas. If you have source material that started as YUV though, you might want to output it in YUV if your next step is encoding. If you are not going straight to a distribution codec and you are going to futz with it in After Effects (which works RGB internally) then you may as well rendering everything out as RGB. You might want to render it out as 10 bit RGB to preserve a bit more range so that later on when you RGB->YUV you get a nicer/smoother result. At any rate, we're splitting hairs here. Using that "bad" RGB->YUV conversion is usually un-noticable unless you do a couple of generations or if you have a really good eye or if you look at the final result on a waveform monitor. |
Re: Sony YUV codec
sub-optimal conversion. Quote:
workflow on a project that I wanted to get good quality out of. If you are comfortable with this workflow, I would recommend doing it. It results in little rounding error and it is much better than the first workflow. If you want almost no rounding error you need to use the SonyYUV output and get a bigger hard drive to deal with all the uncompressed pixels. Quote:
known as YUY2) so what you need to do is re-order the bytes. I usually use Virtualdub to do a fast-recompress between the SonyYUV file and Lagarith running in YUY2 mode explicitly. In this recompresion, the bytes are re-ordered by virtualdub and passed to Lagarith in YUY2 format and Lagarith compresses the file with no colorspace conversion. When you open the Lagarith file in Avisynth, it will pull YUY2/YVUY from the lagarith file and then you can do your YV12. Quote:
conversion from one way representing a color numerically into another that can have rounding errors due to finite precision. That is not to say it is trivial. You do need to tell Avisynth to make the YV12 interlaced or progressive since that changes how the YV12 is calculated. Quote:
not be worth the effort though. |
Re: Sony YUV codec
Well, I can definitely agree on splitting hairs as most of this thread...
But, I disagree on the need to preserve a YUV colorspace, in light of the fact that Vegas composites internally using RGB. The major problem with codecs isn't so much theri color space, but what happens with levels - whether or not they support 16-235 or 0-255 input and how they handle output also. I.e. Sony YUV doesn't give a hoot about levels, but Cineform does. |
Re: Sony YUV codec
Hi
Regards Phil |
