Vegas 10.Exporting for a website
Hola,
which are the best settings to exportand convert an Hd file on a format that could be viewed on a site? thx |
Depends on what format you're site will handle. Personally I convert to FLV but I used to use DV-AVI. Just depends. Does your web host have a preference?
Hi Don, no preferences...
so you suggest to transcode in dv avi then....Which settings on Vegas? thx |
Hi Marcus,
Should you do DV-AVI? Well you can but again I prefer FLV. Smaller file loads quicker and that's what my site is setup for. However if you do use AVI, after editing, then simply goto FILE>Render As and use the pull down menu to render to AVI. Then upload to the host. Or you can do WMV. It's very cut and dry in Vegas. |
Don but HOw do you convert through FLV?
After editing I render to AVI then bring it into a program called FLIX (I'm using standard-there is a PRO version which has more bells and whistles). It's by on2 technology at Home | On2 Technologies. I thinks it's about $25 or $30 USD.
I use a standard template; 512K Broadband Video [VP6-E FLV]. it works great. I think theres a trial version. HTHs |
then there's mp4 - which is what i use.
Flix is now available from wildform.com, price is slightly up at $50, but it is still the least expensive way to get the excellent VP6 codec. |
Thanks for the info Seth. Shows you how long I've been out of the loop. ;-)
Works great so far. Note: Mp4 without the flv wrapper will not play on many computers that people I know have. They do not have the correct codec. The flv wrap with the player works on all of them so far. Living Hope Restoration Branch |
| All times are GMT -6. The time now is 04:15 PM. |
