vegas 9 builds peaks every time I open at DVinfo.net
Old September 8th, 2010, 01:14 AM   #1
I'm assuming that I'm just missing something simple, but everytime I open any saved project in Vegas 9e 64bit it builds peaks. Past versions, once I saved after the peaks were built it would simply open and I could go about my business. It does them quickly, but is becoming a slight annoyance. Just wondering if there is a simple solution.
Frank Grumeretz is offline   Reply With Quote
Old September 8th, 2010, 07:00 AM   #2
Sponsor: JET DV
It should not be building them every time. Once built the first time, that should be sufficient from that point forward. I don't know what causes it to sometimes do that. Is it any one particular file? or all files?
Old September 8th, 2010, 11:54 AM   #3
Yeah weird huh? Vegas 9, 32bit never did it. I installed the 64bit on a new machine about a month ago and it does it on every project which had me thinking it was just a check box in the preferences or something. Matched it up side by side with my other computer running the 32bit version and they are identical. I've edited 4 or 5 projects on the new system and it does it everytime. Is it possible it could be something with the actual computer?
Old September 8th, 2010, 12:15 PM   #4
Sponsor: JET DV
You might try deleting all SFK files and see if that helps.
Edward Troxel is offline   Reply
