Audio behaving very strange
when I apply volume envelope to turn music audio volume down suddenly it becomes like test tone of high frequency and on volume meter is shown like 350+ db. what is going on?
I've never seen an audio envelope do anything like that. Can you give a step by step on how we could try to reproduce that?
I've got a very vague recollection of this being reported on the Sony Vegas forum (which is unfortunately down right now) some time ago.
Something to do with a zero crossing point as I recall. |
2 Attachment(s)
I place music audio file below track with video footage and when I add point in volume line to lower music down it goes to beep of extremal volume AS SOON AS is pases that added point on volume line ( see audio Master reading).
Loud POP sound on 2 envelope points at 90 degrees is the relevant thread on the Sony Vegas forum.
Sony's official response: You are experiencing this 'popping' noise because the audio envelope is being used like a cut, and cutting on a non-zero point will create a 'pop' noise in the audio. We have been able to reproduce this in all versions of Vegas, as well as in Sound Forge. Basically, it is a characteristic of audio editing. If you make a cut or drastically drop volume on a non-zero crossing point, you will hear a resulting 'pop'. |
WHAT!
I am not "cutting" anything I am lowering SLIGHTLY volume of background music to hear narration; Interesting - when I reopen that project and reload that music audio file and do nothing, audio will become beep in very same spot like in last project. Is this like "memory effect"? I had to move the music audio file to different audio track to play it normal. |
Marius, Sony didn't say cutting, they said ...like a cut... which is a world of difference.
This was reported in Pro 9.0a and hasn't been a issue since. What version are you using? Have you tried moving the second point a tiny bit to the left or right to see if this cures it? |
What are the media properties of the audio file that is having the problems?
From the attached screenshot, what you have layed out should behave normally. |
It is regular mp3 file;
