-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Can Vegas be used with divx pro 5.2.1 (https://www.dvinfo.net/forum/what-happens-vegas/34375-can-vegas-used-divx-pro-5-2-1-a.html)
Dwight Flynn November 2nd, 2004 11:26 PM
Is there a plug-in or settings I can get or manipulate to allow divx pro 5.2.1 to work with vegas? I am working on a small project and I have noticed that the divix files will not load properly in vegas.
Edward Troxel November 3rd, 2004 08:26 AM
You will have to locate and install the proper codec. The Vegas should work fine with those files once the codec is installed. There are MANY threads about this - especially on Sony's main forum.
What's the source of these files and why can't standard DV-AVI files be used?
Dwight Flynn November 3rd, 2004 04:20 PM
Edward, the problem I am having is that I was under the impression that once I installed divx pro 5.2.1 onto my system it would play and maybe even encode, but that has not been the case. So if I need to load some other codec, or the divx codec in another form, where do I find out where the codec is for download or purchase.
Edward Troxel November 3rd, 2004 09:31 PM
Here's a couple of links. There are MANY more.
http://mediasoftware.sonypictures.co...ssageID=292955
http://mediasoftware.sonypictures.co...ssageID=265713
Dwight Flynn November 6th, 2004 09:49 AM
Thanks Edward.
Rob Lohman November 7th, 2004 07:08 AM
Are these files in .AVI or some other fileformat (codec does not
have much/anything to do with the fileformat)?
Dwight Flynn November 8th, 2004 05:57 AM
They are in avi. I made them from my m2t files.
Rob Lohman November 9th, 2004 03:37 AM
Which audio codec did you use? You can try loading it into
www.virtualdub.org, does that program give you a
warning on the audio part? I can load xvid files perfectly on
my Vegas installation, at the moment I don't have divx installed,
so can't test that. But with Virtualdub you should be able to
convert it to uncompressed and then load that.
Dwight Flynn November 9th, 2004 02:06 PM
Thanks Rob, I'll give it a try
