pop up bubbles??
I want to add some voice bubbles ala "pop-up videos".
My initial thought was to make the bubbles as jpg files and then put them on higher tracks and fly them in and out via track motion tools. Is there a better way to do this? |
Sounds like that should work. You could also just have them suddenly appear. Or let it fade-in/out (or add a transition to the fade-in/out). Or use the new 3D tools to rotate it in. Lots of options are available.
Yes, lots of possibilities indeed. Do you have a font called Webdings on your machine? It comes free with several Windows versions, and you'll find it floating about the net, too. It has several figures like thought-bubbles, speak-bubbles that may make your task even easier. Choose one solid-coloured version and apply it in the text generator. Then you can make the front colour transparent - the background is transparent by default. Set outline, and reduce the thickness as much as you like. Even if you reduce it to zero there should be a very thin line visible. Use the placement function (in the text generator) or pan/crop to move the figure. Or let the thing mysterously appear by keyframing it in from full transparency on.
Hi,
My only comment is that JPEG files may be a bit too low res. Try Photoshop files or TIFF. |
Using font is a good idea, but you wont be able to type a font within a font for the text on screen. The last post is correct in using photoshop. You will need a graphic with the included alpha matte so you can have a transparent background. A jpg is a rectangle that can be animated, but when you want just the odd shaped bubble to ramp in quickly and then anchor to one position, this will have to be a photoshop layer.
You are correct in that you cannot type both the bubble and the bubble contents in the same text generated media. However, you can add a SECOND text generated media on a track above the bubble to type the text that appears in the bubble. |
JPGs can have plenty of resolution to use. I'd stay away from TIFF as they require Quicktime to use. However, I agree that using a type that allows alpha channel would be best. So, I'd probably recommend PNG or PSD. |
Awesome!
Thanks for the advice. I'll let you know how it turns out and try and get something posted |
Reid,
Someone else recently asked about this, and so I posted a veg file using bezier masks. Using a bezier mask, you can cut a piece of generated media out, and then use that. If you add a compositing mode, you can make it more 'glass-like' or if you wish, you could just add a shadow with Track Motion and forget about doing anything else. Of course, there are lots of WingDing fonts that have cartoon bubbles in them too. |
Thanks Douglas,
I actually just found your vegs up on Sundance the other day. I appreciate the effort involved. I did try the wingdings idea but that didn't work for me, cuase one I blew them up enuf they looked terrible. I have an old copy of Paint shoppro which does have word bubble shapes. I created a couple of different ones as png files. I just had them popin as they appeared on the timeline and floated the test above in another layer. I dropped in a little bubble pop noise and it actually looks good. If I had more time I'd play around with bouncing them in but I need to go ahead and rap this thing up. Thanks again everyone... |
<<<-- Originally posted by Edward Troxel : My only comment is that JPEG files may be a bit too low res. Try Photoshop files or TIFF.
JPGs can have plenty of resolution to use. I'd stay away from TIFF as they require Quicktime to use. However, I agree that using a type that allows alpha channel would be best. So, I'd probably recommend PNG or PSD. -->>> I concurr Yeah.. I've done this before and you need to use PNG as it will allow you to save a transparent background. JPEG won't do it. Also, TIFF is too large. Anytime you need to bring in graphics from Photoshop/Illustrator the best format is PNG. |
Actually, this isn't so. TGA is a better format. Vegas and the way it reads SOME PNGs causes a color shift that several users have observed. Reid, glad you found the popups, hope they were of some use to you. |
Is it known why this happens to some PNGs and not others? Has it been established that the images in these "some PNGs" would not cause a colour shift had they been saved in another format? |
I like to do quick & dirty graphics in PowerPoint. You can even add text. Just copy and paste into Photoshop.
For bubbles/thought graphics, look in AUTOSHAPES, under Call Outs. |
| All times are GMT -6. The time now is 12:14 PM. |
