-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Clip shortened in render (https://www.dvinfo.net/forum/what-happens-vegas/30059-clip-shortened-render.html)
Michael Best August 4th, 2004 06:33 AM
3 minute video rendered mpeg2, watched it and it's over only
2/3 of the way through? Any ideas? Thanks
Edward Troxel August 4th, 2004 07:07 AM
So you are saying you have a 3 minute clip, you render to MPEG2, and you only have the first 2 minutes worth? Did you possibly have a loop region around the first 2 minutes and, when rendering, only rendered the loop region?
Michael Best August 4th, 2004 07:13 AM
Edward, no, definitely no loop regions. There are a lot of edits in the piece, to the point that it would barely play in the preview window but I don't see how that would impact this problem.
Patrick King August 4th, 2004 07:15 AM
Edward,
You're unbelievable. I've had that very thing happen to me (several times) but I didn't recall that as a possible solution. How do you remember all this stuff?
Do you have a little 'pre-render checklist' that you use (deselect loop region, select resample if desired, unmute all tracks, etc)?
Edward Troxel August 4th, 2004 08:05 AM
Michael, what happens if you render to DV-AVI first and then render THAT file to MPEG?
Edward Troxel August 4th, 2004 08:07 AM
Patrick, no specific checklist. I DO make sure I do not have a loop region selected before I start to render (unless I specifically want to selectively render a small section). Otherwise, just a quick double-check of the "Render - As" checkboxes (mainly have to determine whether or not to include markers!)
Michael Best August 4th, 2004 08:16 AM
Edward, I haven't tried that but I can, what would that be accomplishing?
Edward Troxel August 4th, 2004 09:46 AM
Just wondering if there was a complex area that the MPEG2 render was getting hung on and, therefore, wasn't finishing. A loop area is still the most logical reason, though. Kind of grasping at straws here.
Michael Best August 4th, 2004 10:18 AM
I'll try some other things and check for consistency.
Thanks very much
Rob Lohman August 5th, 2004 06:45 AM
This will probably sound silly as well, but check your free disk
space on your temp drive.
Michael Best August 5th, 2004 06:53 AM
Rob, are you referring to a 'temporary file folder'?
Rob Lohman August 5th, 2004 07:05 AM
Yes, it points to a directory on a harddisk. This disk might be full?
(or your MPEG's final output directory)
Michael Best August 5th, 2004 07:07 AM
My drives are set up as follows
100 gig split 20% C: / 80% E:
100 gig H:
160 gig I: External Firewire drive
My operating system is on C: (space remaining on this partition is low)
Vegas is on E:
Captured Files/Projects are on H: sometimes I:
Also, moderately edited projects max out the CPU when previewing, P4 2.53. Ram is running at 50% of capacity.
I can't believe I have to render everything all the time
just to see if a single edit was what I was looking for.
Michael Best August 5th, 2004 07:08 AM
Can I redirect where it points to? I don't want it pointing to my primary drive. I thought I had all Preferences, Properties, etc set up right, maybe not.
Rob Lohman August 5th, 2004 07:18 AM
Yes you can, just follow the instructions in the manual/help.
