-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   No external monitor image using dvstorm2 (https://www.dvinfo.net/forum/what-happens-vegas/29709-no-external-monitor-image-using-dvstorm2.html)
Dwight Flynn July 27th, 2004 10:41 PM
I have an external ntsc jvc monitor which takes svhs and composite inputs. I can't seem to get vegas 5 to display on my external monitor through my dvstorm2 card, using the svhs connection. I know that the card and monitor is in working order, so I am not certain what to do next. The video device in preferences is set to video for windows standard (the monitor does not accept firewire directly). I am uncertain where to go from here....Help.
Glen Elliott July 27th, 2004 11:31 PM
You can only output a video preview via an OHCI compliant IEEE port. Try connecting your DV camera to the PC and the camera to the TV via it's A/V outs (providing your camera supports video pass-through).
Dwight Flynn July 28th, 2004 12:27 AM
Glen, I don't see how that is possible, because I had an MSI tv tuner card installed (no firewire) in my NLE (using vegas), and was able to view an external monitor. I had to remove the card for space reasons but it did work. If my recollection is correct I used the composite/microsoft video option in vegas at that time (since the card did not have a firewire option). I am not certain if the built in tuner is what made the difference or what, but I don't have that option now, and would really prefer to not put the extra strain on my already overused camera. So if there are other options please let me know.
Glen Elliott July 28th, 2004 12:45 AM
Using a TV out is the same thing as simply porting your CPU screen to a Television. If you use this method your not getting color accuracy. To my knowledge the only way to correctly "monitor" your footage on external monitor accurately is via firewire.
Using microsoft video for the output option runs the output through your video card which is then directly effected by the video LUT (video look up table). In other words if you go and tweak color settings on your video card it will DIRECTLY effect your output. You DON'T want that. The only calibrating you want to be doing to get an accurate account of your footage is on the external monitor itself.
Dwight Flynn July 28th, 2004 04:46 AM
Ok, then how about a pc to tv adapter advc300 from canopus, or the GXP-2000 from grandtec. If not these then what, if any, stand alone products do you recommend. By the way does it make a difference if the pass-through is a firewire or a usb line. If all else fails I am getting a new jvc dvhs deck which does have firewire.
Edward Troxel July 28th, 2004 07:22 AM
The ADVC300 would work fine. Don't know the other one but if it is a similar device, it should also work fine. Stick with firewire for the external previews (and capture and PTT for that matter as well). Do NOT go USB.
A deck will also work well. I use a deck for this purpose and get great external previews.
Dwight Flynn July 28th, 2004 09:37 AM
Thank you
Dwight Flynn July 28th, 2004 03:09 PM
By the way Edward, why exactly are you so insistent on not using a usb device for this type of external monitor viewing.
Edward Troxel July 28th, 2004 03:13 PM
USB wants too much CPU time. In fact, I've seen some machines that require USB scanners or printers be unplugged before they will PTT via firewire successfully.
Dwight Flynn July 29th, 2004 06:51 AM
Problem, I have the JVC DH 30000U deck, and I want to be able to use the firewire port as a pass through so I can use the view external monitor option in Vegas to view video on an extrernal monitor or tv. Thus far I have connected the firewire cable to my computer and to the back of the 30000U deck. I then connected my JVC NSTC monitor to the deck via svideo cable. The screen shows the channel and setup setting for the deck but I can't seem to get it to recognize the firewire signal coming from the computer to the deck. What am I doing wrong. What setting should I be using....HELP.
David Mintzer July 29th, 2004 07:21 AM
Okay---Right above the Preview window of Vegas is an icon that looks like a CRT. Click on that. A dialogue box will open.
Under device make sure that OHCI Compliant IEEE 1394/DV is picked and under Projact format make sure NTSC DV output is selected. Also at the bottom, make sure that Recompress edited frames is checked. That should do it.
Dwight Flynn July 29th, 2004 08:04 AM
David, I have tried that (in fact those are the current settings) and still no luck. I have also tried using another firewire port with no luck. I know the ports and deck work because I am able to control the deck using DVHS tool and the firewire ports. Again....HELP.
David Mintzer July 29th, 2004 10:02 AM
Dwight---when you turn everything on, go to the preference file under options and chose Video Device---tell us if under the Details box it says :device available---
Also---right click on my computer, open up device manager---make sure the Firewire card is active and there are no yellow warning icons. Also, find your IEEE 1394 bus host controllers and see if they are OCHI compliant----
Dwight Flynn July 29th, 2004 07:34 PM
David, under the details box in Video Device it says device unavailable. Also, in my computers the two IEEE1394 devices are operational and OHCI compliant. However, Other Devices and its sublink AV/C Tuner is in yellow. This is the because there is not yet a tuner driver for the deck as it was not really designed to be controlled by a computer but rather a camera.
David Mintzer July 29th, 2004 09:26 PM
What about the device manager settings--are the firewire connection (s)OCHI complient--any question marks etc.
