-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   2 more questions: lightening shots and rendering (https://www.dvinfo.net/forum/what-happens-vegas/27797-2-more-questions-lightening-shots-rendering.html)
Adi Head June 19th, 2004 09:23 AM
sorry about bombarding the forum with questions. this is my first real project using vegas and i'm still learning.
QUESTION 1: i have a few under-exposed shots and wish to fix them so that they look better. i found 3 plug-ins which might be useful to do this: BRIGHTNESS/CONTRAST, COLOR CORRECTOR (by adjusting GAIN), and HSL ADJUST (by adjusting LUMINANCE).
i was curious what method you guys think is best to lighten up a dark shot. it was during a wedding reception. it was evening, there was some lighting around, but apparently not enough in certain areas. it is important that the picture quality doesn't change much. i don't want grainy video.
QUESTION 2: what exactly is the difference between pre-rendering and just plain rendering?
thank you all for your patience!
Edward Troxel June 19th, 2004 10:05 AM
Put a small light on the camera to lighten the room! (seriously)
Physically, nothing. They both create new files on the hard drive. Prerenders will tend to be a bunch of small files while rendering will be one large file. However, you can lose the pre-renders much more easily doing normal editing. When you want to render a section AND make sure you don't have to render it again, I will either "Render As..." or "Render to a new track".
Adi Head June 19th, 2004 10:10 AM
thanks Edward. i hope you're not working TOO much overtime because of me :)
next time i definately will be more prepared as far as lighting up the place. but since i'm stuck with these few shots the way i shot them. is there a "preferred" method of correcting the luminance or brightness or whatever?
thanks.
Edward Troxel June 19th, 2004 10:17 AM
Take a look at BillyBoy's tutorials http://www.wideopenwest.com/%7ewvg/tutorial-menu.htm. Hopefully something in there will help you get started.
Glenn Chan June 19th, 2004 11:46 AM
1- I prefer using the color curves for boosting brightness. To boost contrast and brightness the same time, make an "s" curve with most of the curve concave down.
2- If you run problem footage through Virtual Dub first there are some filters in it to reduce video noise.
In Vegas you can use the median filter to do this, but it takes FOREVER to render. It's something like 100:1...
Adi Head June 19th, 2004 11:49 AM
glen: i'll try it. thanks.
edward: i put the link you reccommended on my "favorites" and will definately read through the relevent tutorials. thanks.
Paul Jason June 20th, 2004 04:03 PM
Does Virtual Dub do something that vegas cannot do? I have heard about this program a lot but have never tried it. Is this a program I should try and learn?
Peter Jefferson June 21st, 2004 04:54 AM
yeah but some dude (cant remember the link now) is making a shell for Virtual Dub plugins so u can use the plugs in Vegas.
VD has a great stabiliser :)
Mark A. Foley June 21st, 2004 06:59 AM
It's Satish Kumar
http://www.debugmode.com/pluginpac/frameserver.php
Guy Bruner June 21st, 2004 07:17 AM
Satish's WAX plugin will accept DirectX filters and VDub plugs.
Paul Jason June 21st, 2004 08:40 AM
How about some links to those plug-ins:-)
Edward Troxel June 21st, 2004 09:33 AM
It was indirectly given above. The root url is http://www.debugmode.com. You can find all of the tools Satish has provided with the various links on that page.
Mark A. Foley June 21st, 2004 09:44 AM
Edward,
I don't want to get wrapped around the axle over this...but the link I provided was based on the assumption that Peter was refering to the link to Satish's Frame Server....
Edward Troxel June 21st, 2004 10:06 AM
That's fine. But it IS an indirect link to all of the rest of Satish's tools as well including WAX. Wasn't trying to discredit your link in any way, shape, or fashion.
Paul Jason June 21st, 2004 12:37 PM
Thanks all, Guess I needed to look closer.
(Update) I looked on his pages and didn't find the great stabiliser that Peter talked about.
