Plug in for Masking in Vegas
Hi guys,
Is there a plug in for Sony Vegas that does auto tracking when you are working with Masks? Does Mocha exist for Vegas.... Thanks |
Not aware of anything Thomas, although you would think that with stabiliser plugins such as Mercalli available for Vegas the capability to track moving points across time is certainly there.
The challenge goes out to the plugin developers! |
When I view Mercali working, it analyzes Full Frames and compares FramePosition1 to FramePostion2 and then FramePositionN. Added to which Mercali has this option to weight the analysis to the centre of the frame or to the border. I don't see a grid of points being employed? My other deshake s/w does something similar.
My thoughts are that there would be a need for developers to be able to get at the underlying code to augment a meshing together of "points"? Grazie |
I think, as I read your "other" post Thomas, you have a solution provided by Richard? Yes?
Grazie |
1 Attachment(s)
EDIT: |
You could use Boris RED/Boris FX to do the auto tracking but you have to load the video manually. You drop Boris on the clip and when you open it, you have to manually load the video while in Boris so that Boris has access to the frames. You can then use the Motion Tracker in Boris to do point tracking and attach a mask to the point tracker all within Boris and never leaving Vegas.
~jr |
| All times are GMT -6. The time now is 01:13 PM. |
